Had real problems getting the fuel system primed, worked on it for an hour and couldn't get a drop of fuel to come through-
then I remembered to hook up that little wire on the fuel solenoid----- then it started on the first rotation and idled perfectly !
(say DUUHHHH....
cant believe how smooth it is inside the cab. Cant even feel its running. The motor runs as smooth as silk !
It has a 6 speed manual with high and low range. Tried low range 1-st. It is about 1 foot in 3 or 4 seconds !
Even high range first seems like it may be too low to start off in traffic. 2-nd might be OK ????
Only drove it around the yard so far as I don't have the power steering up yet- pretty hard steering with 31 inchers and no ps. I am hoping it is just air in the lines. going to jack up the front tomorrow and exercise the PS to see.
Will try to post some pick if I can remember my password to the photobucket site.....
Clutch seems to work fine (my first clutch install)
Tranny (somewhere)makes a little noise when I engage the front drive shaft.... may have an issue there.... to sort out later.
Tim
