Something cool I found at a local offroad expo
Postby ford69557ci » Sun Mar 02, 2008 4:56 pm
I will stick with my ats manifold it looks cleaner and takes up less space
ford69557ci
Postby Philip » Sun Mar 02, 2008 8:20 pm
being in the middle of Indiana in 3-4 years and have the manifold break off!
Don't worry Pete I am sure someone would donate one to get you home.
Postby greasemonkey » Mon Mar 03, 2008 12:14 am
GO OVRIT wrote:The KORE trucks don't heat and cool all that many times. They get hot and stay pretty hot until they're done. It does look pretty trick though.
good point. and I didn't mean they'd break right away, just not comparable to the longevity of the cast pieces. if they're tuned length runners it's probably worth it for the offroad racing guys. for them it's probably a great idea; I just think it wouldn't be the greatest for those of us that tow/haul/commute and want stuff to last more than 100k miles. it sounds weird but our engines see more fatigue and wear from heat cycles and short trips than the offroad racing engines see.
'93 250 4x4 NV4500, flatbed, club cab, ex brake, pump tweaked, too many new ideas thanks to you guys.
dubbed the "Mexican Mtn Goat"
..if you find yourself in a fair fight you did not properly prepare..
..hot rodders are the original recyclers!..
greasemonkey
Postby PToombs » Mon Mar 03, 2008 5:37 pm
Thanks Philip, I know I can always count on you SOP guys! :wrench:
Postby DTanklage » Tue Mar 04, 2008 11:00 am
are you all retarded?
THAT is what i was talking about a while back
dont powder coat (sorry who ever that was that bought the black looking one). get the 'jet' coat (that is what the shiny one is) one, wrap the whole thing with the aspestos wrap, and hold on
when it does eventually crack take it off and have it tig welded
i wouldnt use it on a tow rig, but for the toy i think that is the only way to go
DTanklage
Postby greasemonkey » Tue Mar 04, 2008 12:41 pm
it does look cool, has the wow factor. curious about the flow...since they're much closer to equal length, theoretically the exhaust pulses hit the turbine wheel at much smoother intervals, which makes a noticeable difference on a high revving race engine, I wonder if it makes enough of a difference on these things, under 3,500 rpm.
also wonder about the longer runner length as I've always been taught you want the smallest volume possible between the cylinder and turbine.
has anyone seen any dyno-flog comparisons? either way, I'll be picking up my cast 3 piece in a few days, hopefully installing it this weekend and never worrying about having to weld it.
greasemonkey
Postby PToombs » Tue Mar 04, 2008 5:02 pm
DTanklage wrote:are you all retarded?
Yeah! So what!? :rabbit:
Postby TWorline » Tue Mar 04, 2008 5:40 pm
Yeah, what Pete said!!! :tongue:
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby DTanklage » Tue Mar 04, 2008 6:10 pm
no wonder i feel at home here
DTanklage
Postby MunK » Wed Mar 05, 2008 5:20 am
When one of you buys this fancy piece of equipment let me know....I will take your old one off your hands...I looked at mine yesterday and I can't make out the bolt heads from the manifold it's so rusty.
That or I may have to dig deep and buy a ATS 3 piece as much as I don't want to.
Dumb question but..... if folks are making 500+hp with oem manifolds...am I incorrect in thinking "if it works don't fix it" in my build up?
NoRM
91 W250 Nv4500/3.55
85 W350 Crew Cab (soon to be a 6bt/Nv 4500)
MunK
Postby CumminsPride » Wed Mar 05, 2008 5:42 am
You run a good chance of it shrinking and breaking the ears off the head.
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby MunK » Wed Mar 05, 2008 6:30 am
CumminsPride wrote:You run a good chance of it shrinking and breaking the ears off the head.
Thank you.... Now......when I buy a new performance version...I will have an argument to tell myself that makes sense.
NoRM
talking myself into things at a rate of $500 a week or so...
91 W250 Nv4500/3.55
MunK
Postby greasemonkey » Wed Mar 05, 2008 8:53 am
oh, that's it? :grin:
do guys really replace their manifolds with OEM stuff when their manifold shrinks up??
greasemonkey
Postby DTanklage » Wed Mar 05, 2008 9:03 am
my brother in law did but he is an idiot
DTanklage
Postby dvst8r » Wed Mar 05, 2008 11:20 am
They said the Black coating was a new higher temp (iirc 2000F or something like that) ceramic coating, not powder coat.
dvst8r
