door lock issues
door lock issues
Postby kyled19 » Thu Oct 08, 2015 11:11 am
Ok so i have a list of problems with my electric door locks! starts the driver side door will not unlock all the way with the key from the outside, next the driver side door lock and unlock switch does nothing but i have power at the switch and at either end of the switch when to hit lock and or unlock, finally my passenger side door unlock and lock switch works sometimes but only unlocks and locks the passenger door. anyone have any ideas of what might be wrong? or if i have multiple problems! need to fix asap! please help!
93 d350 extened cab dually dennyt stage 2, 3200 rpm gov spring, intake, 4 inch exhaust, he351cw, fass lift pump, and an a518. 4th gen seats
kyled19
Re: door lock issues
Postby Remps » Thu Oct 08, 2015 12:12 pm
Not sure about the electrical issues, but I'd make sure all the moving door lock linkages are well lubricated with wd40 or something similar. I'd spray a bunch right in the keyhole, and wherever else you can get to the linkages. May require removing the door panel. I hate power locks and windows. :lol:
Postby kyled19 » Thu Oct 08, 2015 7:55 pm
I ended up going way deeper than just door panels but i got it figured out! i did use the wd40 trick which worked great! but for the electrical problem i ended up having to run new wire from the passenger side switch over to the drivers side door motor because all the power comes from there. but i got it all ironed out and it works great! if anyone has any questions about the door locks i most likely will be able to answer them i had to study the circuit pretty hard!
kyled19
Return to Electrical
