0-60 vids??!?!
Re: 0-60 vids??!?!
Postby fatty » Sun Nov 08, 2015 5:48 pm
From a stop with no boost, it will light around 25 I think. When it's wet out it'll break the tires loose up to around 55 mph. Doesn't spin much at all on dry unless I'm boosting in 2wd or turning.
Re: 0-60 vids??!?!
Postby spencerdiesel » Sun Nov 08, 2015 7:45 pm
Sounds fun to me! With so much static timing what kind of mpg you get? What times have you run at the drags?
Re: 0-60 vids??!?!
Postby fatty » Sun Nov 08, 2015 7:56 pm
I don't check the mpg, I'd probably cry. :D But I'd guess maybe 10-12 based on miles per tank. I haven't had a chance to run it, I resealed the engine and did a cam swap this spring and it hasn't run right since.
Edit, it could max the speedo before I hit 1/4 mile on a section of road I used a rangefinder to determine the distance. Not really official I know.
Re: 0-60 vids??!?!
Postby spencerdiesel » Sun Nov 08, 2015 8:49 pm
I hear you on that! Just think of the GPM you'd get with a 450 rwhp gas-job :shock: Always makes me feel better anyway. What lift/duration cam? By not running right, it spools the turbo slower?
Re: 0-60 vids??!?!
Postby fatty » Sun Nov 08, 2015 8:55 pm
Spools slow, runs hot and smokey, leaks worse than before, valve lash changes when I drive. I've been really lacking the motivation to fix it so it's been sitting a few months.
Re: 0-60 vids??!?!
Postby spencerdiesel » Sun Nov 08, 2015 9:03 pm
Oh..... :( Just askin, were all your pushrods reinstalled in the same guides they came out of?
Re: 0-60 vids??!?!
Postby fatty » Sun Nov 08, 2015 9:06 pm
Nope I threw them in a pile when I took them out. I put in new tappets though so they couldn't go back in the same ones anyways.
Re: 0-60 vids??!?!
Postby spencerdiesel » Sun Nov 08, 2015 9:21 pm
Oh ok. I don't have the experience to know any direct cause of the issues you spoke of, but worn/used pushrods with new cam and tappets (new everything except pushrods) can cause odd break-in/wear on a new cam. It may possibly be cam wear?
Re: 0-60 vids??!?!
Postby spencerdiesel » Sun Nov 08, 2015 9:30 pm
I wonder if, because used pushrods might need looser/tighter lash, for lash to read correctly (or lash correctly), the rocker is taking up excess slack? Thus the lash issue? My last post sounds funky....
Re: 0-60 vids??!?!
Postby spencerdiesel » Tue Nov 10, 2015 7:40 am
Looked at the 6bt in the shop and I must have been smokin something on those last two posts. Sorry about that....
Re: 0-60 vids??!?!
Postby spencerdiesel » Fri Jan 29, 2016 8:38 pm
I understand its not fun to hold a camera while making a run, so has anyone just timed their 0-anything runs?
12.1 - 12.5 0-60 for me.
Re: 0-60 vids??!?!
Postby fatty » Fri Jan 29, 2016 9:10 pm
I've used a stopwatch and timed a couple 0-60 in about 6 or so seconds.
Re: 0-60 vids??!?!
Postby spencerdiesel » Sat Jan 30, 2016 9:35 pm
Better than my friends 3v GT :lol:
Re: 0-60 vids??!?!
Postby RCCUMMINS89 » Mon Feb 01, 2016 1:29 am
Fatty has sent me a couple vids........his truck moves out quick! It would whoop up all over the Ramcharger in its quickest days. As I have a manual, and he'd be doing 40mph and I'd still be trying to get into 3rd at 25mph.
Re: 0-60 vids??!?!
Postby spencerdiesel » Mon Feb 01, 2016 5:17 pm
How did the 5x18's compare to th 6x13's?
Return to Competition
