draginmopars wrote:the contacts could be stuck on the starter solenoid or the starter
un bolt/ remove the wire ( on the starter solenoid) going to the starter, turn key to run position
put a test light on that terminal
if it lights
that starter solenoid could be bad
if no light
a quick test next is * truck in park / or neutral
touch the starter wire to the same terminal
if it tries to start, contacts in the starter are bad > a easy repair
