Another IP Thread
Another IP Thread
Postby CumminsPride » Sat Mar 08, 2008 9:19 am
Ok so I have my A1000 and 1/2" lines ran but what are you all doing to increase the IP inlet size and what snap ring are you using for the shaft seal? I am putting in 6X.015 sticks and planning on running this pump till failure. Then on to bigger better things. I just don't want to run out of fuel. I am also running a BIG 2micron water seperator/ filter that has 3/4" inlet /outlets. It's like a 90GPH flow filter. So I am just concerned with what you all did to the inlet. Thanks.
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby bgilbert » Sat Mar 08, 2008 11:27 am
Run one of Aeromotive's boost referenced regulators and you won't have to worry about running out of fuel, increasing the inlet size or a silly snap ring :P . Proven to 600+rwhp in a VE truck. Haven't seen any modded inlet or snap ring setups do that :lol: .
Bill Gilbert
Postby CumminsPride » Sat Mar 08, 2008 12:38 pm
KTA has had a retainer ring in his since 01 or somthing he was saying in another post. Aeromotive reg. is what I am ordering but thought while my $$ were catching up I'd mod the pump to be ready for 45psi or so.
CumminsPride
Postby GPSMatt » Sat Mar 08, 2008 1:22 pm
http://1stgen.org/viewtopic.php?t=2205 ???????????????????????
I want to know about the super secrete pump sthi as well.
86 F350 idi
85 F350 crew cab 4x 5.9
95 Lightning
85 GT
GPSMatt
Postby ford69557ci » Sat Mar 08, 2008 3:56 pm
Fyi that 600hp ve truck is running some kind of seal retainer. Really there isnt much you can do to the inlet without removing the pump and tearin it down unless you can figure out how to keep the metal shavings out of the thing.
ford69557ci
Postby CumminsPride » Sat Mar 08, 2008 4:32 pm
Well folks I guess the inlet will stay the same. As for the retainer, what is the O.D. and thickness of the ring that yall are using?
CumminsPride
Postby cummins king » Sun Mar 09, 2008 6:25 pm
i have some stuff that some people aroud here want me to keep a secret, but here it goes,
i have costom made seals for the front of the pumps good for over 75psi and safts speeds over 2500rpm, still waiting to test it but it looks promissing,
my inlet size is 1/4 npt, i wont go much bigger
i have the next pump up from the a1000 and i have the boost refrenced regulator and i will never be able to run it out of fuel
what you should do is buy a working ve pump do the work on it then put it in the truck, i have step by step rebiuld pdf papers on it, its 25mb lots of pics, so if i ever get my internet working propoly i could send it in 3 or 4 emails :lol:
93 4X4 auto
cummins king
Postby CumminsPride » Sun Mar 09, 2008 7:18 pm
Thanks CK! That's the kind of answers I was looking for. The IP will be off shortly. Or when all this ice and moisture quits, I've been working 14 to 20hrs a day.
CumminsPride
Postby KTA » Sun Mar 09, 2008 8:45 pm
I just have 3/8" line to a -6 JIC fitting at the pump inlet, makes it a full 3/8" ID or more throughout the system.
Postby ford69557ci » Sun Mar 09, 2008 10:17 pm
basicly the same as what im runnin on my 12mm pump that in the truck now but the new pump has a larger fitting to match the opened up ports and other mods. but the 3/8 flows fine i cant burn all of the fuel it gets so i must be gettin plenty.
ford69557ci
Postby GPSMatt » Sun Mar 09, 2008 11:40 pm
ford whats your current fuel pump u r running with the c7 turbo
86 F350 idi
95 Lightning
85 GT
GPSMatt
Postby ford69557ci » Mon Mar 10, 2008 6:23 am
I am runnin a 1000 series pump and still the 12mm ip
ford69557ci
Postby cummins king » Tue Mar 11, 2008 7:36 am
you blew your motor up with a 12mm head, ford?
Joel
93 4X4 auto
cummins king
Postby DTanklage » Tue Mar 11, 2008 7:00 pm
you have to drill out the adapter fitting (the metric one (12x1.25?) that goes in the ip and is -6 on the other end). if you just run it as is it will be no where near 3/8". i cant remember what size i drilled mine to, pretty thin tho...
i just stuck a -6jic 90° on that and didnt worry about it necking down a little
but then i am not looking for 600 hp either
least not with that ve motor...
DTanklage
Postby VEfreak » Thu Mar 13, 2008 7:25 pm
Will some explain to me what is involved in a complete fuel system upgrade. I'd like to know all about the boost regulated pump and IP rings and stuff. A system that will support 400 horses
VEfreak
