What does the thing do
Postby spencerdiesel » Sat Jan 02, 2016 6:28 pm
That plug that goes into the fuel filter base, what is it? My friend and I both have a small leak right at / beside that plug and don't know what caused it
Re: What does the thing do
Postby PToombs » Sat Jan 02, 2016 6:39 pm
You mean the bottom of the filter? That is the water drain / water in fuel (WiF) sender.
Postby spencerdiesel » Sat Jan 02, 2016 7:49 pm
The base of what the filter attaches to
Postby spencerdiesel » Sat Jan 02, 2016 8:50 pm
If looking straight at the filter from the driver side fender, attached to the filter housing just above the filter and slightly to the right is an electrical plug. Don't know what it does.
Mine and my friends truck both leak right there
Postby Gots_a_sol » Sat Jan 02, 2016 9:16 pm
Sounds like the fuel heater
-Joe
Gots_a_sol
Postby spencerdiesel » Sat Jan 02, 2016 10:08 pm
Oh ok. What could cause a leak to appear there?
Postby thrashingcows » Sat Jan 02, 2016 11:06 pm
spencerdiesel wrote:Oh ok. What could cause a leak to appear there?
There is an O-ring on the top of the fuel pre-heater. Sometimes when you remove a stubborn filter it can loosen the stud holding the pre-heater...allowing fuel to leak. But be careful tightening it up...you can crank down too much and crack the pre-heater. But it could also just be a tired and worn out O-ring. They are a special square sided O-ring, and I believe you can buy new O-rings from Geno's Garage.
thrashingcows
Postby BC847 » Sun Jan 03, 2016 9:09 am
Postby spencerdiesel » Sun Jan 03, 2016 3:00 pm
Hey you guys thanks, I know what the the thing does now :lol:
Postby spencerdiesel » Sun Jan 03, 2016 3:31 pm
Postby spencerdiesel » Sun Jan 03, 2016 3:36 pm
And while on the topic, why do people do fuel heater deletes?
Postby BC847 » Sun Jan 03, 2016 3:37 pm
Yes.
Because they're often too cheap to fix the thing. (IMO, of course).
Postby spencerdiesel » Sun Jan 03, 2016 3:48 pm
Well dang then what'd be the point of owning a 1st gen ;)
Postby t_ruffcorn » Sun Jan 03, 2016 10:52 pm
I noticed my drain was leaking one day and went to my local case ih and picked up a dual fuel filter setup (off of a magnum tractor) works great for me. Uses an ff42000 and an fs1221.
1993 w250 280k, 5 speed, 6x13 @80lpm, BD pin, 63/68/.80, 4200 gov, fluidampr, studs, springs, pushrods, 182/214 hamilton, W/M, steedspeed, PS I/C
t_ruffcorn
Postby BC847 » Sun Jan 03, 2016 10:56 pm
As an FYI:
If you'll notice, the part numbers for those filter elements:
FF42000: FF = Fuel Filter
FS1221: FS = Fuel Separator.
