2016 BS and Chat Thread!
Re: 2016 BS and Chat Thread!
Postby dazedandconfused » Thu Jan 21, 2016 11:28 am
Okay so those of you who have rebuilt NV4500's what do you use to press fifth gear back on the main shaft?
Postby RumbleFish » Thu Jan 21, 2016 2:12 pm
ihredneck wrote:I did check and the injectors I have are not going to work. Seems they work for 2000-2003, then the next series is 98-99, then 94-97.... so looks like several modifications to the fuel systems through the years.
perhaps some of the changes are just a harness connector? that's happened in the neons I mess with. change the connector and itll work. might be work a look.
Postby DodgeFreak » Thu Jan 21, 2016 4:11 pm
I believe the connection changed in 2000 or 01, I believe 992-95ish are the same and 96 up to 99 (since they changed connectors) are the same. Not sure how big of a hurry you are but I think I have a set. Also for more power if you take the tb off and open the throats and polish them it will improve power according to my butt dyno. I done it to mine and my dad's Dakota along time ago.
Postby DodgeFreak » Thu Jan 21, 2016 4:12 pm
I had a set of 98 injectors I was going to put into my 92 but never got around to it. I'm not sure if I have those or not. I believe they were really low mile ones.
Postby PToombs » Thu Jan 21, 2016 5:15 pm
dazedandconfused wrote:Okay so those of you who have rebuilt NV4500's what do you use to press fifth gear back on the main shaft?
Why would you press it on? I thought it was a slip on and the nut held it. That's why they come loose and fall off, the nut vibrates loose, then the gear slides back and POOF! no 5th gear.
Postby matthewh » Thu Jan 21, 2016 5:19 pm
Wonder the same thing. Watched several videos where guys took newer model injectors and swapped them into older model vehicles. Mainly 4.0 jeeps, other Chrysler cars, etc.
Dogefreak, not in a hurry at all. I bought one new injector to swap with my dead one, just to get it going again and see if it wasn't the issue all along. Eventually id like to change them all out, since I'd bet money there original, and on borrowed time. I'm gonna pull them and clean them this weekend, to help get me by
matthewh
Postby ihredneck » Thu Jan 21, 2016 5:52 pm
PToombs wrote:Why would you press it on? I thought it was a slip on and the nut held it. That's why they come loose and fall off, the nut vibrates loose, then the gear slides back and POOF! no 5th gear.
I was just thinking the same thing. Unless this is off a GM truck which might be different???
But from all the pictures and such I've seen, fifth gear is splined (as well as the shaft) and the 'nut' is all that keeps it in place.
1999 RCSB 1500 24v NV5600
2000 VW Jetta TDI
ihredneck
Postby dazedandconfused » Thu Jan 21, 2016 7:08 pm
Nope has to be pressed on. The aftermarket mainshafts don't.
Postby ellis93 » Thu Jan 21, 2016 7:26 pm
I've never pressed one on. The nut holds that on......even on stock shafts.
Postby dazedandconfused » Fri Jan 22, 2016 3:25 am
They make a tool for it. Had to pull this one off with a gear puller. Needs to be pressed back on.
http://dodgeram.info/tsb/1998/21-10-98a_r.htm
Postby spencerdiesel » Fri Jan 22, 2016 8:23 am
Well, 11" of snow and climbing. Taking the trash out blows.....
Postby BC847 » Fri Jan 22, 2016 8:54 am
NC is getting it's first notable frozen precipitation event. :roll:
Postby spencerdiesel » Fri Jan 22, 2016 10:24 am
I was noticing that as well :? Its all sleet where I'm at, how much you got BC?
Postby ellis93 » Fri Jan 22, 2016 11:14 am
dazedandconfused wrote:They make a tool for it. Had to pull this one off with a gear puller. Needs to be pressed back on.
Still haven't done it,have never had one tight on the shaft. It's always slid off in the hand with the nut removed.
You must be working on a unicorn.
Postby dazedandconfused » Fri Jan 22, 2016 11:22 am
Lol I guess. I'm going to throw it in the press tonight at work and press it on slowly.
