Low rpm surging
Low rpm surging
Postby spencerdiesel » Sat Jan 30, 2016 9:38 pm
Friends '92 5 speed 12v. Roughly 1100 rpm and under it hunts like an old detroit. Load has no bearing on it. Any suggestions or ideas?
Re: Low rpm surging
Postby Remps » Mon Feb 01, 2016 4:10 pm
First thing I'd try is adding a second throttle return spring, if running just the one on the pump.
Re: Low rpm surging
Postby spencerdiesel » Mon Feb 01, 2016 5:22 pm
Thanks I'll suggest that to him. I guess I should put both of mine back on then........
Re: Low rpm surging
Postby spencerdiesel » Sun Feb 21, 2016 6:28 pm
Checked and I believe all is well with the throttle springs. It does have 320k and its an original IP, could excess wear play any roll?
Re: Low rpm surging
Postby adcotton » Sat Mar 05, 2016 7:01 pm
Mine does too. You can adjust the idle above or below it, and the power screw also has an influence.
Have changed injectors, lift pump , governer spring, turbo and fuel filter all at different times and it never changed.
adcotton
Re: Low rpm surging
Postby spencerdiesel » Sun Mar 06, 2016 10:15 am
Hmmmmmm
