matthewh wrote:http://weldingweb.com/showthread.php?9274-Lincoln-weldanpower-HELP
Check this link out, had alot of good info.
You stealing the engine for your tractor? I'd be interested in the welder side if it all still works
matthewh wrote:As luck would have it, think the master crapped out. Pedals still low, unless you give it 2-3 good pumps, as well as the fluid levels being low, and no leaks evident except around the booster, which tells me its failed internally. Sucks, as its my only vehicle right now, but ill try and find a new mfg master and delete the rwal while I'm at it.
dazedandconfused wrote:Got my Cadillac running again. New radiator and another new starter.
DodgeFreak wrote:Well after ordering stuff from Eric my wallet was so light I forgot it at home....which has my badge to get in and out of the shop and build/gates. Lol...and I work an hour from home so its not like I can run home and get it.. thankfully I have a temp badge and I brought my supper and filled up last night lol.
