runaway ??????
runaway ??????
Postby CAJUN 93 » Wed Mar 12, 2008 9:45 am
ok, installed a 3200 spring in a members truck saturday. removed collar and ran fuel screw in. it seemed to bottom out very quickly. reinstalled and cranked vehicle. runs great, snap throttle and it returns normally, no indication of runaway at all.
now its wendesday morning and he calls me and tells me it took of on the highway like the cruise hit resume. he pulls over and the throttles wide open. he shuts it off with the lever on the side of the pump (i'm glad i showed him that saturday ). now when he cranks it it revs until he shuts it off with the lever.
my ???????. can something go wrong in the pump after 3 days of steady driving that will cause a runaway condition. maybe something stuck in the pump and just broke loose?? any ideas. he's having it towed to his house and i'm gonna go check it out this evening. just some thoughts....
thanks
daryl
CAJUN 93
Postby CumminsPride » Wed Mar 12, 2008 10:47 am
Sounds like the throttle shaft is binding somehow. Or the linkage anyway. I doubt it's in the pump.
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby CAJUN 93 » Wed Mar 12, 2008 11:07 am
i wrenched my brain at lunch and i'm thinking the idle screw backed off. he noticed it as he was getting off the highway after about 35 miles of steady speed. i took the screw all the way out and reversed it and i tightened the nut with a punch like always but maybe it vibrated loose while driving. i hope thats all it is.
daryl
ps. i dont think it's in the pump either. it kills right away with the lever and its not surgeing like its bouncing on the governor.
CAJUN 93
Postby TWorline » Wed Mar 12, 2008 6:33 pm
After adjusting my idle screw one time it had a tendency to vibrate in so I got rid of it. ;)
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby CAJUN 93 » Thu Mar 13, 2008 7:27 am
well thats exactly what happened. idle screw moved forward and increased the idle to about 2000 :roll: . it's double nutted and lock tighted now. :D
thanks for all the input
daryl
CAJUN 93
Postby CumminsPride » Thu Mar 13, 2008 8:26 am
Turn the fuel screw in till it idles the way you like, then toss the idle screw in the glove box. 8)
CumminsPride
Postby Begle1 » Thu Mar 13, 2008 8:37 am
CumminsPride wrote:Turn the fuel screw in till it idles the way you like, then toss the idle screw in the glove box. 8)
I was able to get away without the low idle screw before I got my pump rebuilt, now I need about a 1/4 inch.
Postby GO OVRIT » Thu Mar 13, 2008 1:18 pm
Without the low idle screw mine shakes the truck really good idling between 500 and 550. :grin:
GO OVRIT
Postby CumminsPride » Thu Mar 13, 2008 4:05 pm
I idle mine at 800. It kinda pushes on ya a bit in gear but it's always ready to go.
CumminsPride
Postby seeker1056 » Fri Mar 14, 2008 4:07 am
mine has no idle screw either and idle is set at 850 usin the fuel screw - which is bottomed out lol
Drivability appears better at that idle rpm for me anywyas
Sponsors of new truck
Performance Diesel Injection
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
