A518 external cooler
Re: A518 external cooler
Postby liftarc » Wed Apr 06, 2016 11:46 am
Wish I had seen this earlier. I have a 92 d350 auto that Ill be tearing the auto out of including heat exchanger and aux fan setup. Its all in good working order with clean fluid. If you need anything let me know, Id be happy to cut you a deal to help out, maybe barter without cash. I cant pm yet but thats not hard to fix. Im a half hour east of Chico.
92 D350 club cab flatbed dually-201k G360, NP205,D60 swap soon
92 Ramcharger 5.9 Magnum, 46rh, NP241-238k
liftarc
Postby mrc » Wed Apr 06, 2016 4:36 pm
There might be something you can help me on, just waiting on the HE from CumminsPower59. Think he shipped it today. :cheers:
Do you have the steel line that goes from the HE to the front cooler? That's the only one I need. Going to plumb the rest to the rear cooler with hydraulic hose.
Ordered the gasket and bolts from dodge dealer today, hope it was worth it Philip. :D $135
Can't figure how to do the front band (2 turns back ) going to take some thinking, not very much room.
Still looking for a good temp guage/sensor and install into the pan.
Just waiting on parts at this point, mainly HE from CumminsPower59.
92 W350 flatbed with duels, club cab, stock engine, automatic (for now), 4" exhaust, air bags
mrc
Postby Philip » Wed Apr 06, 2016 4:57 pm
They rapped you on that gasket. Last one I bought was $35.
Next time you walk into a dealer ask that parts person if he works on commission. If he does walk out and find another dealer.
I'll call my dealer tomorrow and get a true price on it. Don't take it out of plastic until I post back.
Postby PToombs » Wed Apr 06, 2016 5:04 pm
I use a either 1/4 or 5/16 wrench to turn the band adjuster back out, easier to count the turns. ;)
Postby liftarc » Wed Apr 06, 2016 6:07 pm
mrc wrote:There might be something you can help me on, just waiting on the HE from CumminsPower59. Think he shipped it today. :cheers:
Im sure I have it, I haven't tore anything apart yet. Just found out I wont be home for a couple weeks then the weekend I do get to go home I have to pull a graveyard shift at Sierra Nevada Chico to demo their old hops strainer that we replaced last month. What kind of timeframe are you looking to be running in? I dont mind giving you that hardline but itd be a couple weeks out.
Does that line have npt fittings and if so what size?
liftarc
Postby mrc » Wed Apr 06, 2016 6:48 pm
I'll wait on the gasket Philip, good looking out, think he said $45 for gasket and $5.35 per bolt. Thought it was a little much.
I start work after next week, hoping to have it together by then. But if it doesn't, no big deal. They got me a 2015 F450 with a 6.7 and Bradford bed to haul my new 20' Featherlite. Fits 7 mules and has a tack room. It's a auto, but what can you do. I'll post a picture once I figure out how.
I'm looking to use this truck for hunting season, maybe hauling to Idaho for elk and muleys. Local hunting for sure. If anyone knows a good spot, might be willing to trade for some packing into the wilderness.
Want to upgrade to a manual eventually, but also want this tranny to last a bit longer. Truck has 167k, felt tight before I took it apart.
Thanks for all the info, more questions to follow. :D
mrc
Postby mrc » Thu Apr 07, 2016 9:06 am
Just called another dealer that's a little further away, 1/2 the price for gasket and bolts, they are shipping it to me for $45 less than the other dealer! Want to call them up a give a piece of mind, but I digress. :D
mrc
Postby Philip » Thu Apr 07, 2016 10:59 am
Ok on the gasket list is $48 so they gave you a little off on it. The bolts the list price is $2.77 each. So they are gouging you pretty good on them.
Postby mrc » Thu Apr 07, 2016 1:25 pm
liftarc wrote:Does that line have npt fittings and if so what size?
Believe they are 1/2" npt fittings, someone can correct me if I'm wrong. But 1/4" npt into the tranny. I have that fitting, just need the 1/2" line from heat exchanger to front cooler. Should have 1/2" fitting on one end and slip on towards the front.
Where did you get your getrag 360?
mrc
Postby liftarc » Thu Apr 07, 2016 1:53 pm
If youre in a hurry to get it running you might consider bending some tube and putting compression to npt fittings at the ends. I have copper 1/4" for the clutch hydraulics in my mbz, Id think it would be fine with atf at <250F and the relatively low pressures that its pumped at.
I bought a complete wrecked 5 speed 92 W250 a few years ago with intention to fix it but the frame is toast so its a parts rig now.
liftarc
Double post, sorry
liftarc
Postby mrc » Thu Apr 07, 2016 5:09 pm
liftarc wrote:I bought a complete wrecked 5 speed 92 W250 a few years ago with intention to fix it but the frame is toast so its a parts rig now.
Are you converting to 4x4? Might be interested in the Tcase.
I want to find a junker as well, with the 5 speed, my buddy said he would sell me a rebuilt nv4500 that came out of a chevy for $1000.
mrc
Postby ellis93 » Thu Apr 07, 2016 5:40 pm
That's not the same caliber of 4500 if it came from a gas burner. It's weaker than a getrag in my opinion.
Postby liftarc » Thu Apr 07, 2016 5:49 pm
I am going to 4x4, my main reason for buying the truck even though it was effed up, had 180k and was a damn shame it got wrecked, not a speck of rust just some leaks and the kid I got it from must have maxed the smoke screw. Now Im sitting on an extra 12 valve that needs a home...
If I remember correctly, a chevy nv will take a different t case adapter and youd still be on the hook for the cummins bellhousing.
liftarc
Postby mrc » Thu Apr 07, 2016 8:02 pm
I don't know if I'm sold on getting a nv45, might go for the NV56 or g56. But that's in years to come, hopefully I can make this tranny work a little longer, just afraid about pulling heavy loads, but that's why I bought it. Worst case, I burn up the tranny and have to replace with what I want.
mrc
Return to Transmission
