318 Serpentine belt
318 Serpentine belt
Postby Dodgewade » Sun Nov 13, 2016 8:59 pm
I bought a 95 Dakota with a 318 in it. Will the serpentine belt set up on it fit an older model 318?
Dodgewade
smoke screw?
Re: 318 Serpentine belt
Postby DodgeFreak » Mon Nov 14, 2016 8:43 pm
timing chain cover is different as is water pump. I believe if you swap all the 95 stuff over to a LA it will work.
Postby DodgeFreak » Mon Nov 14, 2016 8:44 pm
are you planning on swapping an older 318 in the 95 because there are some other differences.
Postby liftarc » Thu Dec 01, 2016 8:57 pm
You'd also have to use the magnum alt, cast aluminum bracket, t-stat housing and crank pulley as parts of the serpentine setup but it will fit on an la engine, I've done it.
92 D350 club cab flatbed dually-201k G360, NP205,D60 swap soon
92 Ramcharger 5.9 Magnum, 46rh, NP241-238k
liftarc
