KDP tab/ retainer?
KDP tab/ retainer?
Postby Begle1 » Thu May 17, 2018 11:17 am
Where can I get a KDP retainer all by its lonesome, not part of a kit?
Re: KDP tab/ retainer?
Postby PToombs » Thu May 17, 2018 5:13 pm
You can make one. I just used a pointed punch and staked mine. There are a lot of options, but most people get hung up on the "kit" idea IMO.
Postby Richie O » Thu May 17, 2018 6:54 pm
I peened mine too. My 92 had the external fix done. I think wannadiesel used to do that ( :smurfin: before he was a she :smurfin: ) to some guys trucks. I didn't see it until I took off the cover, but I am glad I did. The case bolts were all loose.
Postby thrashingcows » Sun May 20, 2018 8:11 pm
I agree many people get hung up on a complex fix. I staked one...just a couple small punches/notches in the aluminum bore of the case works well. Other one I used an old U-joint strap cut and holed opened up a bit....worked pretty well too. But the case bolts are probably more of a danger then the KDP as mentioned. ;)
thrashingcows
Postby Begle1 » Mon May 21, 2018 9:09 am
I have it all apart right now.
Idea is to red Loctite all the bolts and retain the pin while I'm in there, right?
Postby thrashingcows » Mon May 21, 2018 1:44 pm
There are 4 case bolts I believe (been a while since I did a set. :P )....yes pull them, clean them good, spray the threads with brake cleaner, dry well with compressed air if possible, then a dab of loc-tite and re-install. There is one bolt behind the cam gear I believe, you can not get it all the way out...just clean it the best you can and loc-tite and re-install.
thrashingcows
Postby Bersaglieri » Sun Nov 25, 2018 8:54 pm
I just peened my KDP in, she was definitely going for a walk. A tab would not have worked with my case.
What's the official number of case bolts? I'd like to make sure I got them all while it's open.
1997 Ram 2500 P7100 6BT - G56 - Dana
2002 Excursion VE 6BT- Allison - Sterling
Bersaglieri
