Bosch Alternator AL6510N
Postby Collers9640 » Sat Apr 14, 2018 11:17 pm
Is anyone else using this alternator??? I just solve an electrical issue is was having.. and now I have another problem...
I installed a Bosch Alternator and used the Pulley off my old alternator and tossed the one that came on the Bosch. Only to find a 1 rib off my serpentine belt ground off. Apparently Bosch Alternators dont line up the same way as the
Densos do. To make matters worse I pretty certain I tossed the pulley that came on the Bosch but I don’t think it had enough groves anyhow.
So has anyone had this problem and does anyone know if there’s a pulley I can get to get things to line up?
Only idea I had was to grind down the case some to try and move it back some.
Collers9640
Re: Bosch Alternator AL6510N
Postby thrashingcows » Tue Apr 24, 2018 1:39 pm
Did the alternator mount properly with no issues? It is a ridged mount system so shouldn't be a a problem with alignment. My guess is either you got the wrong alternator...but labeled correct...or the pulley swap was/is your issue. Could be a bad tensioner pulley, or water pump failing causing the belt to wander....happened to me recently as well.
thrashingcows
Postby Collers9640 » Sat May 26, 2018 7:53 pm
The alternator is correct. To get the OEM pulley to work I’ll have to machine of a 1/16” off where the pulley makes contact with the shaft of the alternator
Collers9640
Postby PToombs » Sun May 27, 2018 5:04 pm
I think for the cost of an alternator (I replaced mine last week) I'd be taking that sucker back to the parts store and raising hell before I had to machine the shaft.
Return to Electrical
