Priming / Bleeding The Fuel System
Postby Mike T. » Tue Jan 23, 2007 3:21 pm
Did any of you guys have to prime the fuel system after the 3200 spring install.
Thanks
93 w350 ext. cab,auto,354s,4"exh., smokey mt.,bhaf,htb2 62/65/12,CoolerTubz, ddp 55lpm inj.,Timed 1/8,Valet Switch,Piston LP,mild pump,3200 spring,ddp pin,Goerend TC,25k gvw trans cooler, deep pan,gauges,egt is pre.
Mike T.
Postby Greenleaf » Tue Jan 23, 2007 3:37 pm
Yeah. Just pump up the system with the lift pump. But gotta have the air filter off and a piece of plywood handy to cover the intake case she runs wild.
I like to have someone start the truck and I'll work the throttle and rotate the shut-down lever if it runs away. Never had to use the board method, yet. The shut-down lever has worked.
Greenleaf
tech specialist/mod
Postby Mike T. » Tue Jan 23, 2007 4:40 pm
Thanks Greenleaf..
Mike T.
