Ignition switch ...maybe?
Postby 92cummins89 » Thu Dec 13, 2018 10:05 pm
Do these trucks have an ignition switch?
When I turn the key on nothing comes on but if I jump the relay that is connected to the start b the truck turns in an runs but I have no gauges or lights or anything any ideas?
1992 4x4, 4” diamond eye exhaust, nv4500, he351cw
92cummins89
Re: Ignition switch ...maybe?
Postby ellis93 » Fri Dec 14, 2018 5:08 pm
Check the fuse links on the driver finder,both visually and physically (pull on either end and make sure they done stretch)
Postby thrashingcows » Fri Dec 14, 2018 5:16 pm
There is a starter relay on the drivers inner fender, one of the 3 small square black relays....not sure which one though. I would also check your fuse panel to ensure all of them are good....remove each one and check on a light.
But it does sound very fusable link related since you have no power at all to any of the circuits.
thrashingcows
Postby 92cummins89 » Fri Dec 14, 2018 6:29 pm
I deleted the fuseable links but I don’t have any lights, brakes turn or head lights
92cummins89
Return to Electrical
