Down again. Charging systwm.
Postby cougar » Mon Apr 22, 2019 8:39 am
Not too long ago I replaced the battery cables and the voltage regulator because the voltage was pulsing and slowly dropped to no charge. That fixed it for a while. Coming home last night the volt meter went full tilt and boiled my battery. I'll have to wait for the weather to clear before I can do any serious troubleshooting. Some mod history to keep it simple; The PCM voltage regulator was bypassed and replaced with the old style external VR a long time ago. The auto shutdown relay was also taken off the PCM's control and is activated by the ignition switch.
01 2500 "the work truck".
cougar
Re: Down again. Charging systwm.
Postby PToombs » Mon Apr 22, 2019 4:36 pm
Sounds like the regulator gave up. Or some wires wore thru and touched causing the full field event. A lot of guys are installing the Transpo regulator, it's a small thing that bolts to the back of the alternator.
Postby cougar » Tue Apr 23, 2019 8:09 am
Even though the voltage regulator was replaced last month, I'm not ruling it out. But usually when it gives up I have zero output. If I loose the reference voltage to it, that's when it go full tilt. I suspect the wiring at this point. It has happened before.
cougar
Postby PToombs » Tue Apr 23, 2019 4:41 pm
The other thing I read is to put a relay to feed the signal to the regulator direct from the battery. Then the regulator sees true battery voltage instead of something less due to bad wires.
Postby cougar » Wed Apr 24, 2019 7:54 am
92s and 93s all ready are, the auto shutdown relay. I just took the relay ground off the PCM and grounded it to the frame. No more CPS related alternator failures.
cougar
Return to Electrical
