Exhaust or Injectors?
Postby nooblet » Tue Mar 25, 2008 9:57 pm
I think I know what the answer to this question is going to be, but I want to see your answers to make sure I'm going with the better option.
I'm either going to put a 4" exhaust, with the stock down pipe and a 5" stack on my truck or buy injectors (probably PoD's). What would you do? Stock turbo with stock housing, stock exhaust with muffler cut out, stock injectors, BHAF, non-intercooled.
I would go the exhaust route to lower EGT's for further upgrades, or am I thinking this will make a larger difference than it will actually make?
Chris
nooblet
Postby cummins king » Wed Mar 26, 2008 5:23 am
with everything being stock a set of pods will be fine with stock exaust, usaly people only upgrade exaust when they upgrade there turbo
93 4X4 auto
cummins king
Postby CumminsPride » Wed Mar 26, 2008 5:58 am
If you're not using a 4" DP I would just do the injectors. Honestly I would probably do some 370's instead.
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby JQmile » Wed Mar 26, 2008 9:49 am
How bad are your EGTs? What will your usage be? If your EGTs are less than horrible I would go with injectors, if they already are super hot, I'd do exhaust.
JQmile
Postby nooblet » Wed Mar 26, 2008 11:43 am
Wow completely opposite of what I thought the responses would be! This is why I'm always glad I ask these questions!
My EGTs are not bad at all, I just thought they would be bad if i got some larger sticks.
I'm going to see what I can get some 370's for and what I can get some PoD's for. I really don't care about hazing at idle and how much my truck smokes (I live in Texas after all ;) ). If I can get 370's for not much more than PoD's I'll go that route, but I'm not going to spend a lot more for something that is only "more efficient".
Thanks for the replies!
Chris
nooblet
Postby nooblet » Wed Mar 26, 2008 11:44 am
JQmile wrote:How bad are your EGTs? What will your usage be? If your EGTs are less than horrible I would go with injectors, if they already are super hot, I'd do exhaust.
I don't tow and I don't sled pull. This truck is just for driving around town and having fun with.
Chris
nooblet
Postby JQmile » Wed Mar 26, 2008 2:25 pm
Yeah if you're just screwing around then I would get injectors.
JQmile
Postby dpuckett » Wed Mar 26, 2008 7:35 pm
Your stock injectors will outrun your stock clutch- BTDT in my 91. Save money for a SBC ConFe.
I'd do exhaust myself, based on the potential I have seen with stock nonIC sticks. bgilbert said he didnt see much gain going from stock to PODs.
Daniel
Postby cummins king » Wed Mar 26, 2008 7:56 pm
in a std there isnt much difrence rom stock to a pod, but in and auto theres a apox. 50hp difrence
93 4X4 auto
cummins king
Postby nooblet » Wed Mar 26, 2008 9:55 pm
dpuckett wrote:Your stock injectors will outrun your stock clutch- BTDT in my 91. Save money for a SBC ConFe.
Daniel
I won't need a clutch any time soon. My clutch is rated for WAY more power than I will achieve in the next few years.
I bought some POD's. I will hopefully have them in next week. Next on the list will be a turbo and exhaust which I will do at the same time. I know you guys are big advocates for 370's, I just can't help but see more power for less money 8)
You can call me stupid all you want, it won't hurt my feelings... I'm used to it :lol:
Chris
nooblet
Postby JQmile » Wed Mar 26, 2008 10:58 pm
I think you'll be fine. Where is your fuel screw at right now? Wherever it's at, crank it up =) last trip to the dyno I gained 25hp with just 1/2 a turn closer to runaway.
JQmile
Postby nooblet » Thu Mar 27, 2008 12:21 am
JQmile wrote:I think you'll be fine. Where is your fuel screw at right now? Wherever it's at, crank it up =) last trip to the dyno I gained 25hp with just 1/2 a turn closer to runaway.
My fuel screw is only 2.5 turns or so. I plan on cranking it up when I get the PODs in. I'm going to do some major tweaking when I get my injectors set up. Right now I just leave it some what conservative to drive around town with. I really do try hard to not make people eat black smoke at every intersection (unless they deserve it of course :evil: )
Chris
nooblet
