Injector question??
Injector question??
Postby mprmn08 » Sat Apr 26, 2008 1:47 pm
Now i've heard this both ways but im not sure on the real answer. :scratch: Will 94-98.5 injectors work in 1st gens. im just curious because there allot more options for those injectors as im sure you all know then there is for our trucks. Thanks for any input. :thumleft:
mprmn08
Postby rbrettctd » Sat Apr 26, 2008 3:00 pm
No theres different pop pressures and spray angles.
Randy
rbrettctd
Postby PToombs » Sat Apr 26, 2008 4:26 pm
The injectors physically won't fit. The body and threads are larger. The tips can be put in 1st gen injector bodies, and the pop set for the VE. But like Randy said, the angles are different.
Postby CumminsPride » Sun Apr 27, 2008 5:17 am
Come on Pete, The bodies and nuts are the same. The lines and angle are the only differences. They will fit right in your head but won't run worth a crap!
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby GO OVRIT » Sun Apr 27, 2008 5:25 am
There are quite a few options for first gen sticks. Just look at the Injector Chart sticky in this forum.
GO OVRIT
Postby TWorline » Sun Apr 27, 2008 9:37 am
Get ahold of Chuck @ New Era Diesel, He has 370 EDMs' or whatever flavor you would like. ;-) http://www.neweradiesel.com/
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby cummins king » Sun Apr 27, 2008 10:21 am
i can also get what ever you want, sencond gen are 14mm instead of 12 mm, the bodys are the same, pop pressure is diffrent and spray angles are diffrent
93 4X4 auto
cummins king
Postby PToombs » Sun Apr 27, 2008 5:19 pm
That's right, the line nuts are what's bigger. :oops: Sorry guys, maybe I should stick with being a smart ass. ;)
Postby dpuckett » Sun Apr 27, 2008 7:58 pm
Nah, Pete, you aint real good at that, either. :lol:
DP
Postby PToombs » Mon Apr 28, 2008 4:47 pm
Don't you have a rear end to clean? :lol:
Yup, I still got it! ;)
