what gears?
what gears?
Postby bradshaw106 » Tue Apr 29, 2008 2:33 pm
going to look at a 92 4wd with an auto. how do i know what gears it has?
thanks
bradshaw106
Postby mprmn08 » Tue Apr 29, 2008 4:19 pm
you can jack the rear up and spin the tires 1 full rev and count how many times the driveshaft turns with 1 turn of the wheels. i.e. driveshaft spins 4.1 times then there 4.10's, spins 3 3/4 times then 3.73's and so on. hope that helps.
mprmn08
Postby nooblet » Tue Apr 29, 2008 11:35 pm
If its stock you can narrow it down to 4.10's or 3.54's. I don't know how familiar you are with gear ratios, but you should be able to tell by driving it.
Also check for a tag on one of the front diff cover bolts, if its still there it will have a gear ratio on it.
Chris
nooblet
Postby PToombs » Wed Apr 30, 2008 5:48 pm
See if the sticker is still on the underside of the hood. :lol: If it's there, it will say.
Postby bradshaw106 » Wed Apr 30, 2008 6:19 pm
thanks im looking at the truck this friday! guy has dropped his price to 4000 obo!
bradshaw106
