by KTA » Wed Apr 30, 2008 2:39 pm
Typically those tractors run 200+psi, they can take a lot more cylinder pressure than the 6B can because they are wet sleeved and much heavier built. Those blocks do typicaly break along the cam, bore though as that is a weak area. The Deere blocks break the same place.
