Top Speed (stupidity)
Postby cummins king » Sun May 11, 2008 7:07 pm
dazedandconfused wrote:
cummins king wrote:
mhuppertz wrote:
KTA wrote:My truck has spun the rollers past 160mph on the dyno, and somewhere around 140 is the fastest it has been on the street. Of course since it traps the 1/4mile at about 110 it sees that pretty regular. 8)
Geez! What kind of overdrive are you running, and how what's the RPM at 140 and 160?
hes talking about mph not rpm, and hes running a 5spd
and its not a cracker box, it wrenching service in a flash :lol:
I think flying brick is what Brian called it right after he made the 48*hp run years back. Not sure of the gearing probably 3.55 in a dana 80 and a getrag is what is in that truck.
5spd = Getrag
It also equals NV4500 which is what the fellow who posted this has in his truck acording to his sig. Just trying to be as percise as can be. :D
:thumleft:
93 4X4 auto
cummins king
Postby KTA » Mon May 12, 2008 5:32 am
Yes I have 3.31 gears and run 32" tall tires with a getrag 5 spd. It will pull well past 4200rpm, it just doesn't pull as well as at 3000rpm. 8)
Postby racerdude_9 » Mon May 12, 2008 5:39 pm
what mods do u have to have to get 120mph let alone 160?
1991 CTD
racerdude_9
Postby dodgetkboy78 » Mon May 12, 2008 11:49 pm
Damn you guys, my truck does 94, uphill, downhill, and probably sideways.
dodgetkboy78
Wind Resistance
Postby Ace » Tue May 13, 2008 6:40 am
Wind resistance is the biggest speed-limiting factor for a pickup shaped like ours. Top speed is going to be more drag limited than power/gearing might suggest. For every 10% speed increase, drag increases by over 40%. You just can't make enough power to go over a certain speed with these vehicles. Laws of physics and all...
Re: Wind Resistance
Postby PToombs » Tue May 13, 2008 4:16 pm
Ace wrote: You just can't make enough power to go over a certain speed with these vehicles.
Maybe not, but it sure is fun tryin'! ;)
:lol: :lol:
Postby mhuppertz » Tue May 13, 2008 6:35 pm
Not a problem until you hit around 700 MPH!
mhuppertz
Postby racerdude_9 » Tue May 13, 2008 6:40 pm
that would be awsome!!! :P :P :D :o :hs:
1991 CTD
racerdude_9
Postby Cschafer » Wed May 14, 2008 8:04 am
I'm personnaly a little gun shy about speed after the driveshaft came out at a 110 :cry: but that was at about 3300 so It's got some left.
91 w250 wrecker
Cschafer
Postby PToombs » Wed May 14, 2008 3:11 pm
Oh come on, you were on the dyno! :shock: It woulda been worse if you were actually driving! :lol:
Postby Cschafer » Wed May 14, 2008 6:44 pm
there being the reson i'm gun shy :cry:
91 w250 wrecker
Cschafer
Postby 89silverbullet » Wed May 14, 2008 10:15 pm
we could just be like the bugatti veyron, we could run a v-16 diesel ( not that primative gas stuff) with 10 intercoolers.
1989 d250 muffler delete diaphram turned, fuel screw turned, the lowes special intake
89silverbullet
