Turbo question??
Turbo question??
Postby mprmn08 » Tue May 13, 2008 6:51 pm
I just bought a turbo off of a 94 and i want to hook the wastegate up but obviously my 90 didnt have one. on the 94's there wasnt a fitting on the boost side of the turbo like the 95 and later's. My question is where would i tap into for the wastegate control on my motor with that turbo? Would i just drill and tap a port into the the crossover tube for it? thanks for any input guys.
mprmn08
Postby Cschafer » Wed May 14, 2008 7:38 am
that would work or anywere else you can get a boost signal. If it's the wh1c just pull the vee band on the compressor housing and tap it right into the outlet like the newer trucks.
91 w250 wrecker
Cschafer
Postby Ace » Wed May 14, 2008 8:23 am
That's where I put the one I briefly experimented with last year. It's presently plugged - waiting for fuel....
