fuel solenoid
fuel solenoid
Postby mikcon » Mon May 12, 2008 7:39 am
How many amps does it take to pull it in and how many to hold it?
I need to just put it on a switch let me know if ya know.
Mike
mikcon
Postby BEARKILLER » Thu May 15, 2008 9:50 am
I can't answer your question in exact amps required; but, it can't require very much.
If it did, the flimsy key-switch would soon melt-down.
Just about any decent toggle-switch should carry it fine.
MY TRUCK = 1985 FORD F-350 2wd, 89 1st.Gen.Cummins,Getrag 5-sp,Dana70 3:55
WIFE'S TRUCK = 1991.5 D-250 I/C, Auto
SON'S TRUCK = 1990 W-250 Getrag
#4 = 1991 D-350 LE Getrag
BEARKILLER
Postby mikcon » Mon May 19, 2008 6:28 am
thanks
mikcon
Shutoff Solenoid = Dumb
Postby Ace » Mon May 19, 2008 6:42 am
That fuel shutoff solenoid is nothing but a problem waiting to happen. It's a luxury convenience designed to make the engine shut off with the ignition (duh) switch like a gasser. Gut it, install a pull cable and be done with it. Even then, it can leak. I went all the way and not only gutted it, but drilled it out, tapped it and turned the dumb thing into a solid plug.
Postby Lee Majors » Fri Jun 27, 2008 8:42 am
So fuel solonoid could be what stops a truck from getting fuel when cranking? When a truck will just turn over and over and over and seems like its getting no fuel?
1991.5 D350 dually flatbed stock
Lee Majors
Postby Begle1 » Fri Jun 27, 2008 9:30 am
Lee Majors wrote:So fuel solonoid could be what stops a truck from getting fuel when cranking? When a truck will just turn over and over and over and seems like its getting no fuel?
Yes, a faulty fuel solenoid circuit is the main cause of no-starts on the 1st gen Cummins. It's also a common source of stalls.
That said, I wouldn't go out of my way to rip it out. It's worth having for emergency shut down reasons at the minimum. If it was acting up I'd take it out.
Postby Lee Majors » Sat Jun 28, 2008 3:23 pm
mine won't start right now...it will crank and crank and crank with no fire. Seems like its not getting any fuel that's why I asked. Even with a healthy dose of Ether it pops off on the ether but never keeps running after the spray is burnt.
Where on the pump is this solonoid? can I bypass it?
Lee Majors
Postby MudSlinger79 » Fri Jan 02, 2009 7:31 am
Can u just remove it and install a plug the size of the cut off?
93 Ford, 1st Gen Cummins, 66/71/14 S-300, New Era 435 Sticks ,Pump Cranked, denny 2 fuel pin, afc MIA, 3200 spring. Sitting on 5 Ton Rockwells With 63" Rice And Canes. More To Come!!
MudSlinger79
Postby PToombs » Fri Jan 02, 2009 7:48 am
No, just remove the plunger and small spring that goes inside of it. Screw the solenoid itself back in. Make sure the o-ring is on the end, that's the seal.
Return to Electrical
