Do you guys pull the upper ball joint to swap springs? Or pull the rotor?
The other thing I noticed, the upper ball joint wasn't tight in the hole, it popped up. I'm gonna have to tach weld that sucker in there too.
PToombs wrote:The other thing I noticed, the upper ball joint wasn't tight in the hole, it popped up. I'm gonna have to tach weld that sucker in there too.
