perplexed
Postby bgilbert » Tue Jun 10, 2008 1:38 pm
Something's not right with those injectors. I switched from POD's to Scheid Diesel 6x16's and gained 10psi of boost. Then to KTA's (Buddha Power) 6x18's and gained 3 more psi of boost, with NO other changes at either injector swap.
Postby bgilbert » Tue Jun 10, 2008 3:57 pm
What size injector washers did you use with the POD's and now with these?
Joel, who made, where are they poppin? EDM, extrude hone, drill bit?
Postby KTA » Tue Jun 10, 2008 8:27 pm
Try setting your AFC tighter to decrease fuel, that should make it quicker.
Postby seeker1056 » Wed Jun 11, 2008 5:21 am
Thanx Brian - I will try that
Sponsors of new truck
Performance Diesel Injection
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby seeker1056 » Thu Jun 12, 2008 5:45 am
fun and games
The afc made it somewhat better - till I blew the convertor - pulled it out last nite and it sounds like a party favour inside with all the bits rattlin around in there
New one with torringtons n furnace brazed with a 1400 stall on its way
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby Cschafer » Thu Jun 12, 2008 1:07 pm
Kinda figured it was the converter. My 6x.018's made mine light like crazy and I had the afc bottomed too. I even have stock timing.
Oh FYI Bill there probobly edm's and come from the same place as 99% of them in the country right here in michigan.
91 w250 wrecker
Cschafer
Postby CumminsPride » Thu Jun 12, 2008 2:49 pm
Are you refering to JL Machine? 8)
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby Fnschlaud4620 » Thu Jun 12, 2008 3:30 pm
sorry about the converter, I feel bad it blew, but I kinda feel good cause I guessed right! :P
Fnschlaud4620
Postby SChandler » Thu Jun 12, 2008 4:05 pm
Since you're getting a new converter, any thoughts on a lock-up converter? I know the C-6 automatics were non-lock-up, but could you adapt a lock-up style? From my reading, it seems like lock-up is beneficial in sled pulling, might be time to incorporate it?
SChandler
Postby mprmn08 » Thu Jun 12, 2008 4:53 pm
see i would think if your trans is a non lock up then it would be better to stay that way cause a lock up convertor just has one more part in it that can fail. thats just my opinion though, im no trans specialist or anything.
mprmn08
Postby bgilbert » Thu Jun 12, 2008 7:11 pm
I was wondering where JL was located. I must be in the 1% bracket :D .
Postby bgilbert » Thu Jun 12, 2008 7:12 pm
Postby Begle1 » Thu Jun 12, 2008 10:40 pm
1400, eh? That's loooowww...
Postby SChandler » Fri Jun 13, 2008 7:47 am
1400 sounds low until you strap a 40k sled to the back end :lol: . I bet in use it doesn't stall until 2000 (or higher).
SChandler
Postby bgilbert » Fri Jun 13, 2008 8:05 am
Hard to get a big turbo or turbo's lit sled pulling with a low stall.
