turbo question
turbo question
Postby mprmn08 » Mon Jun 30, 2008 6:57 pm
can i put a hx35 compressor wheel and housing on a wh1c turbo without any mods??
mprmn08
Postby CumminsPride » Tue Jul 01, 2008 4:43 am
No, the HX uses a snap ring and the WH1 uses a clamp. The center sections would need to be swapped also. Why is the HX any better than a WH1C? :? They're both 54mm compressors.
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby dpuckett » Tue Jul 01, 2008 10:02 am
HX35 is a 56mm compressor. The internal guts are the same- you buy a rebuild kit for a H1C/ HX35/ HX40/ H1E.
Daniel
Postby CumminsPride » Tue Jul 01, 2008 11:26 am
Not according to HTT, read the first part description: "This upgrade converts your stock HX35W turbo to our most popular HX35/HX40 hybrid turbo.
It increases the air flow capacity of your stock turbo to match the increased fuel flow of performance fuel injectors and performance chips.
Your stock compressor wheel measures 54mm."
Here's the link for the non believers > http://htturbo.com/cu.htm
CumminsPride
