fuel solenoid
Postby Lee Majors » Mon Jun 30, 2008 9:59 am
Is it possible that air could be stuck in the fuel system not allowing the fuel to pressurize in the fuel lines?
1991.5 D350 dually flatbed stock
Lee Majors
Postby Begle1 » Mon Jun 30, 2008 10:53 am
Lee Majors wrote:Is it possible that air could be stuck in the fuel system not allowing the fuel to pressurize in the fuel lines?
Yes, that's very possible and very common. To check, you have to crack the nuts on top of the injectors while cranking and crank until fuel is coming out of each injector.
Postby cummins king » Mon Jun 30, 2008 8:14 pm
im suprized you didnt crack the injectors, expesialy if you have the sylinoyed out for awhile,
93 4X4 auto
cummins king
Postby Lee Majors » Tue Jul 01, 2008 3:02 pm
I did crack the injectors. No fuel while cranking and that's with gutted fuel solonoid. A bad lift pump should free flow atleast some fuel right?
Lee Majors
Postby PToombs » Tue Jul 01, 2008 6:20 pm
Not usually if you have air. It takes a while to pump fuel up with the lift pump. Did you make sure the fuel filter was full? Bleed from the LP to the IP? Loosen nut on the out line on the LP. when you get fuel, tighten, loosen bleeder above the fuel filter, pump some more. When you get fuel there, loosen line on IP near timing case, pump it again. Then do injectors.
Or you can cheat, and run it on ether until the air is out. (but you still need to bleed the injectors ;) )
Postby Lee Majors » Tue Jul 01, 2008 6:29 pm
That's not a bad idea. I can say I have tried alot but not that yet....so tomarrow I will give that a try.
This thing sounds nasty with to much ether. More than one spray and it sounds like the valves are being bashed through the valve covers.
Lee Majors
Postby PToombs » Tue Jul 01, 2008 6:40 pm
Yeah, it's not really a good idea. I just use enough to get it off the starter, a fine mist.
Postby Lee Majors » Fri Jul 04, 2008 5:51 am
truck is up and running as of this past Wed. night
runs like a champ now with a new lift pump,gutted fuel solonoid & ignition key switch.
Lee Majors
Postby PToombs » Fri Jul 04, 2008 6:14 pm
Glad to hear you got it going. Now you can put the shut off solenoid back together. ;)
Either that or you gotta join the "pull cable" club. :lol:
