Custom Fab'd Dash???
both inside and out
Postby hassy21 » Sun Jul 06, 2008 1:12 am
Has anyone put all aftermarket gauges and replace the whole dash with a fab'd one in one of these trucks say like a real racecar? I make my own bodies for my racecar and have access to a sheet metal brake so that wont be a problem but just wondering if anyone has done or attempted to do this? Any suggestions welcome in fabing the dash and cluster with all of the a/c and electrical in some what of the stock position.
1990 Dodge CTD,4wd,91 frontend conversion, Skyjacker 6" lift, 6" stacks,fuel screw 3/4 turn away from runaway,366 spring,afc delete,timing bump,piston lift pump,autometer gauges,05 Dodge wheels with 35's
http://s54.photobucket.com/albums/g118/imca21/
hassy21
Postby dpuckett » Tue Jul 08, 2008 7:19 am
I'd like to see this when you get done. I have often contemplated (when things slow down) doing this same thing to my pickup, but I'd like it to fit the OEM bezel, or make one similar so it looks somewhat OEM, and not hacked like some redneck job. I think they had it right with the late 70s (I think) when they had the speedo in the middle, 4 circles for 2" gauges on one side, and another big circle (tach, maybe?) on the other side.
I think you have a good idea. Keep us updated on the progress.
Daniel
Postby RumbleFish » Tue Jul 08, 2008 8:58 am
I hate the 70's dash, they make me wanna :puker: in my own mouth
Owning several 80's and early 90's trucks, i always thought it would be cool to use something like this
its a 5" quad gauge by autometer, and they have matching 5" tachs and speedos. iirc the stock dash panel has about 5" openings. its something custom, yet fits in the stock dash holes. i dunno about using the monster tach in a diesel though, this plan was for my ramcharger.
Postby hassy21 » Tue Jul 08, 2008 2:41 pm
dpuckett wrote:I'd like to see this when you get done. I have often contemplated (when things slow down) doing this same thing to my pickup, but I'd like it to fit the OEM bezel, or make one similar so it looks somewhat OEM, and not hacked like some redneck job. I think they had it right with the late 70s (I think) when they had the speedo in the middle, 4 circles for 2" gauges on one side, and another big circle (tach, maybe?) on the other side.
Daniel
ya i want to keep the oem style just make it pop out more because in my opinion Dodge has been behind on the interior for quite some time. The 3rd gen trucks have pretty nice interior though.
thanks
hassy21
Postby done_my way » Sun Jan 18, 2009 3:25 pm
done_my way
Postby PapeCAT » Sun Jan 18, 2009 4:14 pm
Looks Great
Also I have comtemplated putting the custom guages in the stock 70's grille. You can fit the speedo, f 2" ones to the left, a 3" pyro to the left of those and then yes anotehr 3" on the right of the speedo.
PapeCAT
Postby done_my way » Mon Jan 19, 2009 2:01 pm
I modeled the layout after a '92 Dakota the wife was driving at the time. Kind of a pain, but its only time... Been off the road for over 3-years. Funny how it went from a spring swap to a Big-Block install, rear R&P, front end swap, blah blah blah... It would get finished quicker if I would stop changing my mind...
done_my way
Postby doublel89 » Sat Aug 01, 2009 12:05 am
hopefully this winter i can get back to you about this. i plan to get a plasma cam cut out designed to fit in the stock dash with room for about 15 toggle switches for my tcc , od, and many lights and miscelanious stuff in my truck. also have holes cut out for auto meter guages basically make it look like a semi dash. i think it'll look freakin sweet and my cab won't be a 'presidential solution' anymore.
91 3/4 Ton 4x4, 5.9 Cummins,DDP Fuel Pin I usually leave it out though, DDP 40 Horse Sticks, HX35W And 2nd Gen Intercooler, Single 5'' Trunout, NV5600 Swap, Dually Conversion, 3.08 Rear Gears, Soon A Custom Hauler Bed
doublel89
Postby done_my way » Sat Aug 01, 2009 6:47 am
User Mad Max on here and www.ramchargercentral.com has a really nice dash in his Macho Nacho Ramcharger. It is a nice layout, in my opinion.
Here is a link to a pic of his:
http://ramchargercentral.com/index.php?topic=101983.0
My wife keeps telling me my Cummins is on E-bay...
done_my way
Postby Crossy's son » Mon Aug 03, 2009 11:19 am
I saw a stewart warner 5000rpm monster diesel tach one time. on the dash of a 92.
It had a shift light and everything.
90 D250 727 3.07's 227k miles
Crossy's son
Return to Body
