Got bored and ground on my fuel pin
Postby gear jammer 91" » Wed Jul 09, 2008 7:12 pm
So, I had nothin better to do tonight so I pulled my fuel pin and got the grinder out. I'm pleased with the result but I think I might be able to safely take a little more off If I had a better grinding bit. What do you guy's think.
01 LB7
gear jammer 91"
Postby Philip » Wed Jul 09, 2008 8:47 pm
Thats a lot of extra metal you left. You should see the ones greenleaf grinds. :lol:
Postby gear jammer 91" » Thu Jul 10, 2008 4:25 pm
The only grinding bit I had was a stone bit that was about a half inch in diameter. I just went out and bought a new grinding bit that is only about 3/16 in diameter, so I should be able to get the rest of that unneeded metal out of there. :lol:
01 LB7
gear jammer 91"
RE: fuel pin grind
Postby captcavy » Thu Jul 10, 2008 4:37 pm
hey gear jammer 91", buy you a dennyt stage II fuel pin, its the best pin out there, hardened stainless steel, cnc machined, he even polishes the
cut side to a mirror finish, the pin dyno'd 52hp at the rear wheels,
he sells the pin for 100.00 dollars shipped to the door, you cant grind a stock
pin to even compare to this pin, just some info for you, shelby, aka captcavy
I bought one but havent installed it yet, it is a beautiful pin.
captcavy
Postby captcavy » Thu Jul 10, 2008 4:47 pm
delete
captcavy
Postby gear jammer 91" » Thu Jul 10, 2008 8:38 pm
I'm gonna see what I can do with my new bit cause I'm cheap, but a hundred bucks ain't bad. You got a picture of the dennyt stage II pin?
01 LB7
gear jammer 91"
dennyt pin
Postby captcavy » Fri Jul 11, 2008 1:14 am
this is his stage I pin, the stage II pin is more agressive, shelby
here's a link to a picture of the stage I
http://www.dieseltruckresource.com/pics ... 00/pin.jpg
captcavy
Postby captcavy » Fri Jul 11, 2008 2:08 am
delete
captcavy
Postby captcavy » Fri Jul 11, 2008 2:33 am
delete
captcavy
dennyt fuel pin
Postby captcavy » Fri Jul 11, 2008 2:46 am
here's a good picture, pin on left is a bully dog, middle pin is factory
the pin on the right is a dennyt stage I pin, the stage II pin is even better
it is cut deeper allowing maximum fuel, cant go any more deeper otherwise
the fuel pin wouldnt touch the pin in the pump at the deepest point, shelby
http://i290.photobucket.com/albums/ll27 ... 0_0157.jpg
captcavy
Postby bradshaw106 » Fri Jul 11, 2008 12:52 pm
in one of the above posts it is mentioned that the fuel screw can be turned in untill the marred threads from the collar are about to enter the pump...
mine wasn't even close i got about 3/4-1.5 turns and thats it.
any thoughts?
92 4wd 180k auto, 366 spring, turned fuel pin, loaded
first diesel!
bradshaw106
Postby PToombs » Fri Jul 11, 2008 6:11 pm
There is a shoulder in the screw hole that the o-ring on the screw seals against. The screw will only go in this far, it starts to bind. If you go farther, there is a good chance the fuel will start to leak around the screw because you ruined the sealing surface. Mine is in this far and where the collar was isn't near the lock nut.
Postby rbrettctd » Sat Jul 12, 2008 11:05 am
I run a stage 2, and I upgraded to it from an already very ground pin and man, what a difference. Its time for me to do my lift pump now lol.
Randy
rbrettctd
is it possible...
Postby T.winegar » Sat Jul 12, 2008 3:17 pm
could a person fill in the back side of the stock fuel pin with a wire-feed welder(just barely enough to make it a full pin), then take a grinder to it and make it look like like a custom built one like the stage II?
89 727-stageIvcomp 4in intake-amsoil air filter, 4in exhaust, dennyT, 366 spring. pump turned up to make me smile! low stall converter, rebuilt tranny at 120,000miles
T.winegar
Postby CumminsPride » Sat Jul 12, 2008 3:27 pm
I don't see why not. The only question would be the hardness of the welded material.
06 3500 AT Mega Cab SRW 4X4
CumminsPride
