want power!!
want power!!
Postby T.winegar » Sat Jul 12, 2008 10:54 am
i have an 89 dodge cummins noni/c- 727 3spd auto. HTT stage IV compressor, 4in intake(amsoil air filter), 4in downpipe. i don't want to spend money on injectors, and want more power out of it. what can i do with it to see some more 'go'. i have grinded on the fuel pin slightly. not really even much smoke though. i also have a 3,200 rpm spring on the way.
ideas???
89 727-stageIvcomp 4in intake-amsoil air filter, 4in exhaust, dennyT, 366 spring. pump turned up to make me smile! low stall converter, rebuilt tranny at 120,000miles
T.winegar
Postby rbrettctd » Sat Jul 12, 2008 11:03 am
Do you have gauges and have you messed with the pump other than the fuel pin? You can turn the fuel screw for the easiest free power, but dont do it without gauges.
Randy
rbrettctd
Postby T.winegar » Sat Jul 12, 2008 4:26 pm
haven't touched the pump, but my 366spring got here 10 minutes ago and i'm about to go install it. once installed, i am going to play with my fuel screw again, and pin
T.winegar
Postby oldcool90 » Sat Jul 12, 2008 7:01 pm
Grind your afc foot when you do your gov spring them two mod will wake her up :D .
oldcool90
Postby T.winegar » Sat Jul 12, 2008 11:07 pm
how much grinding on the 'foot', and where is that located at? i had the top off my pump tonight and saw a few things that may be what you're talking about. i'm not finished with it, so i can still get to it possibly...
T.winegar
Postby oldcool90 » Sun Jul 13, 2008 5:28 am
With the top off the pump you should see a u shape metal with a small foot on it. It is held in by a pin that goes though the top and has two ball bearings that hold it in,one on each side.Take a driff punch and drive the pin,and ball out then flip over and drive the pin out the other way to knock the other ball out.If you pull a trailer or heavy loads you might want to take the whole foot out that way if its too much you can reinstall and you are back to stock.Just grinding a 1/16 off of mine added 7 lb of boost.That gov spring will do you good to :D
oldcool90
Postby CumminsPride » Sun Jul 13, 2008 7:24 am
I took mine clear out. Very recommended for the hot rod trucks, not so much for a tow piece though :mad:
06 3500 AT Mega Cab SRW 4X4
CumminsPride
