BHAF Part numbers
BHAF Part numbers
Postby shoot4fun » Thu Feb 21, 2008 1:33 pm
This info is probably here somewhere, but I thought I'd gather a little bit of it into one place.
These are all WIX numbers. NAPA is the same, just drop the first number.
HEIGHT: OD: INLET: PART#
10.880 x 8.5 x 3.054 - 46314
11.880 x 10.5 x 4.00 - 46423
12.380 x 8.5 x 3.00 - 46634
12.380 x 8.5 x 4.00 - 46637
(all dimensions are inches)
The above filters are self contained, and are disposable. Housing is plastic and can be used as dust/heat shield with a little modification.
I have also found some other filters with housings that have 2 holes, possibly for a cold air intake tube routing that would eliminate the need to build a box or cover? Some are larger than those listed here. If anyone is interested, I can post part #'s for those as well.
Hope this helps.
Brad
'92 D250 4WD, Bone Stock except for the '78 Ford Crew Cab body that's getting ready to land on it...
shoot4fun
Re: BHAF Part numbers
Postby Begle1 » Sun Aug 03, 2008 9:14 pm
shoot4fun wrote:I have also found some other filters with housings that have 2 holes, possibly for a cold air intake tube routing that would eliminate the need to build a box or cover? Some are larger than those listed here. If anyone is interested, I can post part #'s for those as well.
Hope this helps.
Brad
These sound kind of interesting to me.
What would the be called even?
Postby RumbleFish » Mon Aug 04, 2008 4:59 am
interesting to see that the generally accepted bhaf number, 42790, did not make the list. id like to see how it compares to the others.
Postby Begle1 » Sat Aug 09, 2008 8:12 am
From NAPA Online:
FIL 2790
HGHT: 11.88 in
OD: 10.5 in
TOP: Closed
Note that the 2790 has the same listed dimensions as the FIL 6423. But, the 2790 is $76 while the 6423 is $80. The 6423 has "extra holes" in the side in the picture.
FIL 6343
HGHT: 9.781 in
OD: 7.875
TOP: Hole
A stock filter costs $43.
How are guys mounting these to the stock intake? The stock filter is 4 5/8's inner diameter; is it common to trim out the middle of the BHAF to get back the lost diameter?
And how is it stuck on to any air intake? Drill a hole in the top, get a long piece of allthread and use a grommet?
Seems to me like the stock filter is from from restrictive at my current power level. And the inner diameter of the stocker is bigger than any of the BHAF's.
I wonder if I can mount two stock filters in my box...
CFM
Postby Ace » Sat Aug 09, 2008 11:47 am
They key spec you are not mentioning is the CFM rating (cubic feet/min.) The stock filter is rated around 450cfm. That's enough to support up to a little less than 300hp, based on some complicated fuel-air combustion efficiency formula with many variables. The BHAF's flow alot more.
Postby Begle1 » Sat Aug 09, 2008 11:57 am
How do you find CFM ratings?
Postby Ace » Sat Aug 09, 2008 12:05 pm
