AFC lever removal
AFC lever removal
Postby gear jammer 91" » Wed Jul 23, 2008 4:50 pm
If I remove the AFC lever from my pump and re-install the pin it rides on, would it have any negative affects on the pump that would cause me not to be able to re-install the afc lever latter on? I want the extra power for the dyno, and the strip, but I want controllable egt's, and decent mileage for normal driving and towing. Also if the afc lever is removed could you just take a couple turns out of the full power screw to get the mileage and lower egt's back? Basically I want wicked power, when I want it, and good mileage when I don't. :mrgreen:
01 LB7
gear jammer 91"
Postby gear jammer 91" » Sat Jul 26, 2008 8:53 pm
Since nobody knows, has anbody removed their AFC lever instead of grinding it?, and do the little ball bearings still seal the pin in after you've removed them, or does their fit in the pump top start to loosen up?
01 LB7
gear jammer 91"
Postby DTanklage » Sun Jul 27, 2008 1:23 am
being that you have a manual trans you will prolly never put it back in but yes you could and no, your balls wont leak
you can put some j-b weld or green loctite on them if you are paranoid
you are gonna like it too much to ever reinstall
or, you could build a valet system using a ground foot afc with a longer pin and a solenoid
DTanklage
Postby Begle1 » Sun Jul 27, 2008 4:11 am
DTanklage wrote:or, you could build a valet system using a ground foot afc with a longer pin and a solenoid
Any more specific idea on how to do that? I've been thinking about a servo or solenoid controlled valet on the actual lever for a while...
Postby CumminsPride » Sun Jul 27, 2008 7:22 am
I just tapped the holes with a 1/4-20 and ran in some small set screws with locktite. Worked slick and reinstall would be a cinch.
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby CaptainChrysler » Tue Jul 29, 2008 2:50 pm
I want to do this mod to the '89.
Will removing the AFC lever give you more fuel than just removing the fuel pin?
If you remove the AFC lever, you need to keep the pin that rides on the fuel pin in there to plug the hole right?
Thanks
1993 W-350 EXT CAB SRW
GETRAG, DC-1'S, 285'S
370'S, HX40, 5" EXHAUST, BHAF
1989 W-350 SRW
GETRAG/NV273
P-PUMPED, 2.6" S400
WATER-2-AIR IC, SBC DD
CaptainChrysler
Postby DTanklage » Tue Jul 29, 2008 3:37 pm
yes and yes
it gives you more...but not as much more as you are hoping it does
lol
DTanklage
Postby gear jammer 91" » Tue Jul 29, 2008 8:35 pm
How bad does removing the AFC affect mileage?, is the answer, you don't want to know. :lol: I think I still use my truck for commuting to much to take a big mileage hit in the name of more power. :cry: I quess I could just get some good rain gear and ride my KTM year round. Of course around here you damn near need a snorkel in the winter cause it rains so much. :lol:
01 LB7
gear jammer 91"
Postby oldcool90 » Wed Jul 30, 2008 3:43 pm
gear jammer 91" wrote:How bad does removing the AFC affect mileage?, is the answer, you don't want to know. :lol: I think I still use my truck for commuting to much to take a big mileage hit in the name of more power. :cry: I quess I could just get some good rain gear and ride my KTM year round. Of course around here you damn near need a snorkel in the winter cause it rains so much. :lol:
It's not the afc you need to worry about it's your right foot. :lol: Grinding just a little off the foot like a 1/16 to an 1/8 gave me almost 10lb boost moore,and i even backed the fuel screw off a 1/4 turn close to run away.
oldcool90
Postby gear jammer 91" » Thu Jul 31, 2008 5:00 pm
My right foot tends to get pretty heavy, especially on freeway on ramps. :lol:
Maybe I'll get bored this weekend and remove it and see what I think.
01 LB7
gear jammer 91"
Postby DTanklage » Tue Aug 05, 2008 2:15 am
you shoulda removed it
(i know you didnt or you would be on here asking why you didnt do it a long time ago)
don
DTanklage
Postby railhor5.9 » Tue Aug 05, 2008 5:24 am
NEW TO THE ROTORY PUMP... WAT LEVER ARE THEY TALKIN BOUT? ANY PICS?
1993 d250,single cab short bed, sbc, 175hp p-pumped,4kgsk,370's, fass 150. hx35
1997 2500 4x4 , 913,191's,3kgsk,5x16, 3rd gen dubs.
railhor5.9
Postby CumminsPride » Tue Aug 05, 2008 6:38 am
It's in the top of the pump cover. Read through the 3200rpm install and where he points out the afc foot to grind, just remove the whole lever. A small punch knocks it right out.
CumminsPride
Postby railhor5.9 » Tue Aug 05, 2008 9:44 am
IS IT BAD ON THE PUMP??? HOW MUCH HP DOES IT ADD??? REV HIGHER? :?:
railhor5.9
Postby DTanklage » Tue Aug 05, 2008 10:57 am
search 'case pressure gauge' - the pump is lubed and cooled by fuel, hows your supply system?
it adds power everywhere - only down fall is that as soon as you come off idle pump thinks you are at max boost (ie fat)
gov spring determines point of defuel
DTanklage
