BHAF
BHAF
Postby peobryant » Mon Jun 02, 2008 6:36 pm
I'm sure that this has already been answered before so sorry for bringning it back up again. I need to buy one, so does anybody have a link to a site to buy all the materials? Thanks.
Postby CumminsPride » Mon Jun 02, 2008 6:52 pm
They have everything including the filter at a fair price. http://store.airflo.com/
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby peobryant » Mon Jun 02, 2008 7:03 pm
Sorry for the stupid question, but what exactly do I need to buy?
Postby roxxx » Mon Jun 02, 2008 9:31 pm
here this is a great set up i used the Cummins AH19037 instead of their filter. you can make your own quite easy but this is the general idea http://asamodifieds.com/new_page_2.htm
This is the other one i was considering
http://store.airflo.com/psi-03.html
1992 4x4 Reg cab LE 5 speed
4 Inch lift
Bilsteins shocks 5125
VE moderately molested
Dana 80
ultra wheel rims Type 164
ASA pipe BHAF 19037
Outerwears prefilter
A A nv4500
roxxx
Postby oconnellrb » Mon Jun 02, 2008 11:19 pm
oconnellrb
Postby peobryant » Tue Jun 03, 2008 6:12 pm
Thanks for the quick reply, looks like i'll be ordering some parts this weekend. Thanks again.
Postby rattlebox93 » Mon Aug 25, 2008 7:28 am
i used a stock commonrail intake 4" to 5" elbow some 5" exhaust tubing and a k&n filter it worked great ill have to get some pics up
rattlebox93
Postby Begle1 » Mon Aug 25, 2008 7:57 am
Are those "rubber hoses" that they sell good quality? Or are they just plain old rubber?
You really want to avoid the rubber and use silicone tube, right?
Postby PToombs » Mon Aug 25, 2008 5:49 pm
On the suction side it doesn't matter so much. No pressure, and the suction isn't much on a 4 or 5" hose.
Unless the filter is plugged. ;)
Postby Begle1 » Mon Aug 25, 2008 9:33 pm
Doesn't rubber crack within a year and get degraded when it comes into contact with oil and grease?
Does anybody use it on their trucks? I was under the impression that I only ever saw silicone, that's all.
Postby PToombs » Tue Aug 26, 2008 7:28 pm
Fix the oil leaks. ;)
The original is rubber, mine is still good, but the black comes off on my hands now, so it's starting to go.
