low rider 1993 d250
low rider 1993 d250
Postby boomer » Tue Sep 09, 2008 8:54 pm
Im jealous....most of the D250's I see. 1991-1993 (like mine)...are wheelers.
Mine aint...its a club cab 2w.
they all are "higher"...and ride level...the front end is at least 12 " higher than mine....and mine has always leaned forward...the back is higher than the front.
AT one time I visited a suspension shop and they said...ya can't lift the front on a 2w d250 with the diesel....they aint designed for lift.
live with it ...was the bottom line.
Are those guys wrong? can I lift the front without screwing up the trucks suspension or basic geometry too much?
If so....let me know
boomer
Postby grumpy » Tue Sep 09, 2008 9:09 pm
I too would like any input onthis subject.I've thought about putting airbag's inside of the coil's to help this out (the leaning)that is..
93 dodge w350 excab daully auto 3600 gov spring 4" streight pipe,hx-35/40 turbo
91 jeep xj trail rig I-6 5spd exo cage 7inch lift
87 35ft gooseneck trailer soon to have 79camper on it.
grumpy
Postby PToombs » Wed Sep 10, 2008 4:33 pm
I don't know how many miles you guys have, but I had over 200k and my springs were junk. I replace them with the Moog 7226S heavy duties and Bilstein shocks. Raised the front up about 3-4 inches.
If it leans, there was a TSB on that. There is a shim available that goes under the spring on the drivers side, levels the truck out. I didn't bother with that.
Now my rear sits lower than the front. Airbag time! ;-)
Postby dpuckett » Fri Sep 12, 2008 8:45 am
The trucks are supposed to be lower in the front to become level after being loaded.
Pete, your fronts were shot; are your rears the same way? Flat leafs arent stronger than arched ones! Kinda like the steel belts showing in your tires arent extra taction.
DP
Postby PToombs » Fri Sep 12, 2008 2:19 pm
Dan, well duh! I know they're whipped! I thought I'd add bags to level and help carry the load. ;)
Postby 92d250 » Sun Sep 14, 2008 8:55 pm
Trying not to hijack your thread but i have a set of 5 inch lift springs for chevy truck do you guys think they will work?
1992 D250 370,000 and counting on the cummins, auto, pump turned up, 6x16, 3200 spring, afc lever mia, boost and pyro guage, single stack, 5 inch lift, shifter with od button on it, potentiomitor..... Next hx40, 285's...
92d250
Postby dpuckett » Sun Sep 14, 2008 9:10 pm
They could raise the rear, but the underlying problem would still exist- flat springs. My D350 sits about 4" higher in the rear than Mom's
DP
Postby 92d250 » Sun Sep 14, 2008 9:23 pm
They are from the front
92d250
