guages
guages
Postby T.winegar » Sat Sep 27, 2008 8:39 pm
i have a tachometer, and a tranny temp gauge, but nothing else. where is the cheapest place to get a couple good gauges- egt's and boost i figure i want to know where my truck is running at, and if it safe or not..
89 727-stageIvcomp 4in intake-amsoil air filter, 4in exhaust, dennyT, 366 spring. pump turned up to make me smile! low stall converter, rebuilt tranny at 120,000miles
T.winegar
Postby xpetecx » Sun Sep 28, 2008 7:09 am
ive always got mine from dieselmanor.com dont know if there the cheapest right now but at the time I got mine they were.
xpetecx
Postby 1991cummins » Sun Sep 28, 2008 8:48 pm
i got them from truckcustomizers. i had to google them to find them though, my friend told me about them. they had cheap autometer gauges
1991cummins
Postby rbrettctd » Tue Sep 30, 2008 6:16 pm
egauges.net
Randy
rbrettctd
Postby Begle1 » Tue Sep 30, 2008 9:04 pm
The semi-junkyard for a pyro. Those are hard to find for cheap.
But, dial pressure gauges can be found at Harbor Freight. They are used to measure tire pressure. You can find ones that go up to 65 PSI for $1.49.
Postby T.winegar » Wed Oct 01, 2008 9:57 pm
how do i hook up a tire pressure guage to my turbo. and would i need more than 65psi reading for a stage 4 compressor?
T.winegar
Postby Begle1 » Wed Oct 01, 2008 10:35 pm
You wouldn't need more than 65 PSI unless you had twins or some very big single, or a single wayyy out of map.
It takes a bit of creativity to hook a tire pressure gauge to an NPT fitting. Shouldn't be too hard of a thing to do, ya know, but as far as I can find those fittings don't exist. I know a guy local that could make a line, but he'd charge a few dollars.
I just took an old QR-1 valve off the front axle of a class 8 that had a ripped diaphragm; replaced the QR-1 diaphragm with a valve stem out of an old tire, then screwed the gauge to the stem. Works great. 8)
If I did it again I'd probably take the gauge apart and see if there was a metal part on the inside I could tap for NPT.
