276hp665tq,welding truck,new era 370 edms,asa intake,3200 spring,htt manifold,ground fuel pin,fuel skrew not all the way in yet
I am more than happy with that. That was with my custom ground fuel pin, 40%meth, 3200spring, BHAF, 4" turbo back, Long bolt instead of smoke screw holding the fuel pin all the way down all the time, piston LP, IP tight against the head, mystery intercooler on a non-ic truck, HX-40, fuel screw 1/8 turn from a runaway. I think that's all I have done. It was run in 4th gear, and I didn't get a chance to run it on #2 only. I don't know if they used any kind of correction factor or not, but we are at near sea level here and it was overcast and like 60 outside.
gear jammer 91" wrote:I'm not sure how they got my engine rpm. I didn't know I could ride along in the truck when they ran it, so I didn't see what they did. I think they might have just plugged some kind of pickup into my cigarette lighter. My dyno sheet has mph on it not rpm, so I'm gonna stop by there tomorrow and get them to re print it with the engine rpm.
Begle1 wrote:But you have another few GPH due to the blown headgasket.
