THE ULTIMATE FUEL MILEAGE THREAD
Postby KTA » Tue Feb 13, 2007 8:21 pm
This is aimed to be the best fuel economy guide for 1gen trucks out there. please post which catagory your vehicle falls in and your average mileage. please dont post your best ever numbers, this is general averages.
catagories;
Truck Avg MPG
1. 89-91 D250/350 single wheel manual trans 17-18
1a. 89-91 D250/350 single wheel auto trans
2. 89-91 D350 Dually manual
2a. 89-91 D350 Dually auto
3. 89-91 W250/350 single wheel manual 17-18
3a. 89-91 W250/350 single wheel auto 18-19
4. 89-91 W350 dually manual
4a. 89-91 W350 dually auto
5. 91.5-93 D250/350 single wheel manual trans 18-19
5a. 91.5-93 D250/350 single wheel auto trans 17-20
6. 91.5-93 D350 Dually manual 18- 19
6a. 91.5-93 D350 Dually auto 17-18
7. 91.5-93 W250/350 single wheel manual 15-17-22
7a. 91.5-93 W250/350 single wheel auto 17-18
8. 91.5-93 W350 dually manual 16-17
8a. 91.5-93 W350 dually auto 18-20
Postby cumminsram » Tue Feb 13, 2007 8:23 pm
category three and about 17mpg
03 duramax reg cab 4x4 6sp blue, daily driver
93 w350 reg cab 4x4 5sp single wheel
sold: 1993 auto 4x4
SOLD:1990 power ram 250 4x4 5sp
cumminsram
Postby DLittle » Tue Feb 13, 2007 8:41 pm
Where's the 92-93 W250 srw auto ? manual ?
or 92-93 w350 dually auto, manual ?
mines a 1993 W250 auto average 17 mpg
Dana
1992 W250 auto, 290 k, stock for now SOLD
1973 W100 SWB, D70,D60, 5.9 Twin Turbo SOLD
1993 W250 193k, Auto, TOTALED 10/30/2009
DLittle
Postby 92 D/UNIT » Tue Feb 13, 2007 8:53 pm
# 7
15 mpg
92 w 250 manual
388/886
92 D/UNIT
Postby bgilbert » Tue Feb 13, 2007 9:04 pm
#3 18mpg.
Bill Gilbert
Postby Philip » Tue Feb 13, 2007 9:17 pm
#8
With the stock dually bed 18 to 20 depending on speed.
With the flatbed 16 to 18 depending on speed.
Keep in mind I have 3:08's.
Postby TWorline » Tue Feb 13, 2007 9:28 pm
#7 17mpg. normal driving
20mpg. @ 65 mph. interstate driving.
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby KTA » Tue Feb 13, 2007 9:35 pm
phillip i dont think i can count yours since its an off spec, do you know about what it averaged before the axle changes?
Postby Philip » Tue Feb 13, 2007 10:16 pm
Mine came with the 3:08's from the factory.
It has a build date of 12/92. This puts it right close to the end of the model year. My closest guess is the factory had this set of axles laying around and dumped them into this truck to get rid of them. The plant most likely shut down in May of 93 for the 94 year change over and retooling.
I have a set of Dodge saleman litature for 93 trucks. The 3:08's are listed as an option for the 93 250's with a stick shift also.
Postby Bookshelf » Tue Feb 13, 2007 10:38 pm
From current and past experiences, these are all at least 50 deg ambient temp, summer blend fuel, and mostly trips of 10 miles or more, mixed city/highway
3a(91 W350 SRW auto 3.07's) 18-20
5(91.5 D250 5 sp 3.54) 19.5
7(93 W250 CC 5 sp 3.54)21-22
7a(93 W350 SRW auto 3.54)17-18
91.0 W250 Auto
90 Chevy V30
Bookshelf
3a(91 W350 SRW auto 3.07's) 19
7(93 W250 CC 5 sp 3.54)22
7a(93 W350 SRW auto 3.54)18
91.0 W250 Auto
90 Chevy V30
Bookshelf
Postby jogl » Wed Feb 14, 2007 4:35 am
7a: 16 mpg (US gallon) it will probably be better in summer when not idling as much.
JP.
92 W250 and lots of others.
jogl
Postby KTA » Wed Feb 14, 2007 6:15 am
Thats cool Phillip, I think the 3.08's were a special order. I know a guy that had a 91 5spd that was custom ordered from the factory with 3.08's. I didnt realize it could still be done so late as I thought they were discontinued as an option when the 727 trans was dropped.
Bookshelf your 93 W250 seems to average exceptionally good mileage, any ideas why that might be? Whats your setup on that truck?
Postby Philip » Wed Feb 14, 2007 6:35 am
KTA the litature I have doesn't list the 3:08's for dually's just 250's with a stick only. The litature I have is what the dealer salesman would build a truck with if you went in 93 to order one. So if it wasn't in this book you couldn't get it.
I think this truck was a dealer stock order. On a stock order the factory can fudge with some items. I think this set of axles was laying around and they just dumped them in to get rid of them. Before the body change.
As far as I have seen or heard this is the only dually above 91.5 that has this gear ratio from the factory.
I just wish they had made a mistake and installed a 47RH while they were at it. :lol: :lol: Then I wouldn't have to put one in myself.
Postby Bookshelf » Wed Feb 14, 2007 7:14 am
KTA wrote:Bookshelf your 93 W250 seems to average exceptionally good mileage, any ideas why that might be? Whats your setup on that truck?
Thats the truck in my sig, it got around 18-19 when I got it, then I put a 4" exhaust on, BHAF, played w/ the pump, and a 366 spring. I got almost 24 a couple of times w/ it. This was all summer driving, and most of those trips were 30+ miles. I posted a thread on "other" forums about it, and other guys reported the same mileage w/ theirs. With my 91.5 D250, I got 20 towing my 20' big block ski boat, and got 23 a couple of times also, and that truck was stock. I think the basic mods I have on my 93 really help mileage.
91.0 W250 Auto
90 Chevy V30
Bookshelf
