electric pump vs pistn lp
Postby mtm93ramnasty » Thu Oct 16, 2008 9:02 pm
whats a good electric pump for run on my truck i still have the stock pump turnd up it just needs to fuel the 6x18s i was going to get a pistn lp but idk if thats going to be able to keep up with that much fuel.
93 ctd pump maxed, little bit of timing, fuel pin ground, 3200 gov spring, 6x18 injectors, hx40, CoolerTubz, southbend con fe, isspro guages boost+pryo, 5in exhaust, home made intake w/greens airfilter
340hp 739tq no ksb hot wire stock lp
mtm93ramnasty
Postby 92firstgenctd » Thu Oct 16, 2008 9:07 pm
I am in the process of puting a holley blue pump on my truck, 14psi, 160 gph. I will let you know how it works if you want.
92firstgenctd
Postby mtm93ramnasty » Thu Oct 16, 2008 10:59 pm
let me know how that works out
mtm93ramnasty
Postby mtm93ramnasty » Mon Oct 20, 2008 9:19 am
so with the mods in my sig wold a pistn lp even be worth doing? or would i have to run and electric pump
mtm93ramnasty
Postby CumminsPride » Mon Oct 20, 2008 11:54 am
Don't bother, BC847 is ditching the piston LP due to low psi. I think you will have more room to grow with the Aeromotive A1000 and Bypass Regulator.
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby Begle1 » Mon Oct 20, 2008 12:40 pm
Why not a second gen piston lift pump and a bypass regulator?
Postby mtm93ramnasty » Mon Oct 20, 2008 1:57 pm
i have a 2nd gen lp just sittn at my shop i was thinkn about hookn it up w a reg and backn it with a holly blue pump, but i got a buddy that can get me a really good deal on an airdog 510$ for their best one brand new plus what ever it would cost for all the new lines too.
mtm93ramnasty
Postby BC847 » Mon Oct 20, 2008 2:21 pm
The 2nd gen LP regulated is what I'm dumping. Not that it doesn't do a good job, it's just that I'm moving out of it's league.
IMO, it will not reliably support the 6x18's (@ WOT). ;)
At this point in time, I'm running . . .
- Regular DDP4's (not the plus model).
- Typically maxed VE IP with a 3200 gov spring and Denny-T fuel pin
- The above is timed at about 2.25mm.
The current Lp system is . .
- AN6 supply from pick-up in tank to the IP.
- Stock/OEM 1996 CTD piston LP.
- Aeromotive bypass type regulator just before the IP.
As such I'm able to pull the fuel pressure down low enough that with getting off the fuel at the end of a pass, more often than not, the engine will die and need the injector lines burped to get it running again. :roll:
I think the 2nd gen LP regulated is an excellent choice for a mild to moderately fueled truck up to approx 350hp (in the general scheme of 1st gens).
I'm gonna go ahead and sneak in a Walbro 392 and be done with it. :)
Postby mtm93ramnasty » Mon Oct 20, 2008 3:12 pm
so what your saying is even me putting the 2nd gen lp on with an electric one is just a waist of my time?
mtm93ramnasty
Postby BC847 » Mon Oct 20, 2008 6:23 pm
mtm93ramnasty wrote:so what your saying is even me putting the 2nd gen lp on with an electric one is just a waist of my time?
Running the two in parallel would work. I think that's what Wannadiesel does. The piston LP for regular driving, the Walbro for when he needs extra fuel. (Don't quote me on that).
What I said above is that the 2nd gen piston lift pump combined with a regulator (to keep from blowing the OEM IP seal) will support about 350hp.
Unless I'm sadly mistaken, the 6x18's are very much capable of MUCH more HP and will require more fuel than the piston pump alone can support. :)
Postby mtm93ramnasty » Mon Oct 20, 2008 7:29 pm
i think thats what im gonna do then i have a 2ndgen lp just sittn ill buy a regulator maybe ill back it with the airdog idk
mtm93ramnasty
Postby fergavs » Mon Oct 20, 2008 8:25 pm
The Airdog units are the way to go in my opinion. I run one and have a number of friends with them. I run 6-18's with a 14mm h/r and at idle the pump puts out 28psi and at WOT it puts out 28psi. I have had the truck over 115mph (on the gps) and it was still puttin out 28psi. If you want solid pressure, great filtration and lifetime its the way to go. I run a Airdog150 but a 100 would be good for most people. Also if you dont want to spend the cash just get a Raptor100. Its a solid amazing pump that has an adjustable regulator and lifetime warranty.
fergavs
Postby bgilbert » Tue Oct 21, 2008 7:25 am
The low pressure piston LP helped me put down 450rwhp with stock fuel lines FWIW. All depends on what your end goal and use of the truck will be. Plus whether or not you intend on running a 14mm head and rotor.
Bill Gilbert
Postby mtm93ramnasty » Tue Oct 21, 2008 8:01 am
im probibly not going to run a 14 pump my goal is to see what i can get out of a 12. i probibly wolnt throw anymore fuel at it after i figure out what im going to do about a lp im probibly going to start doin internal work. i want to get a pdr head, i have a custom ground marine cam im buying from my brother and possibly some other things i also know i need to upgrade my turbo
mtm93ramnasty
Postby Ace » Tue Oct 21, 2008 9:14 am
Fergavs, where is your fuel sourcing? Stock pickup? Have you ever run a piston pump?
