4" Crossover tube?
4" Crossover tube?
Postby Begle1 » Tue Oct 21, 2008 10:02 pm
Has anybody ever seen a 4" cross over pipe?
I thought I had seen one... But looking at it now, things would be tight.
Postby gear jammer 91" » Wed Oct 22, 2008 9:45 pm
I remember seeing pictures of a 3" crossover pipe that someone had built, I think it was over on DTR :mad: It hit the sound deadening material on the under side of his hood, but it fit. I think any larger and the hoods not gonna shut.
01 LB7
gear jammer 91"
Postby Begle1 » Wed Oct 22, 2008 9:53 pm
I got 4" clamps, so the current idea is to get 4" pipe and clamp it down into a 3" thick ellipse.
Should be doable, right?
Postby CaptainChrysler » Mon Oct 27, 2008 9:52 am
Where there's a will, there's a way. :D
From what I have gathered anything bigger than 3" is not practical or even necassary.
I am building a 3" one right now. Will have pics when the compressor cover gets here.
1993 W-350 EXT CAB SRW
GETRAG, DC-1'S, 285'S
370'S, HX40, 5" EXHAUST, BHAF
1989 W-350 SRW
GETRAG/NV273
P-PUMPED, 2.6" S400
WATER-2-AIR IC, SBC DD
CaptainChrysler
Postby Begle1 » Mon Oct 27, 2008 12:43 pm
I can see 3" being more than enough for the crossover tube diameter, but it seems to me that any added area to the plate on the head would help spread air to all of the cylinders.
What we really need is either a twin-ram setup like what Jim Lane's got, or a big fan-type manifold like what comes on a lot of heavy duty/ industrial applications and is open along the entire head.
The manifold fabrication itself would be easy, but some funny injection lines would be necessary as well. I'm sure there's a practical limit to how ling injection lines can be, right?
Postby CaptainChrysler » Mon Oct 27, 2008 3:33 pm
You are talking about building a new top plate altogether?
I was going to, then the whole injector line deal changed my mind.
Factory water to air aftercooler injector lines would probably work.
1989 W-350 SRW
GETRAG/NV273
P-PUMPED, 2.6" S400
CaptainChrysler
Postby Begle1 » Tue Oct 28, 2008 12:03 am
CaptainChrysler wrote:Factory water to air aftercooler injector lines would probably work.
I've never seen them.
What do those injector lines look line?
Postby CaptainChrysler » Tue Oct 28, 2008 10:12 am
like this:
1989 W-350 SRW
GETRAG/NV273
P-PUMPED, 2.6" S400
CaptainChrysler
Postby Begle1 » Wed Oct 29, 2008 12:34 am
Ohh yess... That looks like it would be a step in the right direction.
How much do you think those lines would cost? :shock:
Judging by the spacing on the injectors, it looks like it'd let you have a nearly two-foot spread instead of the stock two-inch spread.
Postby CaptainChrysler » Wed Oct 29, 2008 5:34 am
Begle1 wrote:Judging by the spacing on the injectors, it looks like it'd let you have a nearly two-foot spread instead of the stock two-inch spread.
???? I don't follow?
For the custom intake cover?
1989 W-350 SRW
GETRAG/NV273
P-PUMPED, 2.6" S400
CaptainChrysler
Postby Begle1 » Wed Oct 29, 2008 9:32 am
Yeah, it'd let you drastically enlarge the mouth of the intake-to-head mounting surface.
It'd probably be as beneficial as having your cylinder head ported.
Postby CaptainChrysler » Wed Oct 29, 2008 12:28 pm
Yeah it pretty much leaves the whole area wide open.
1989 W-350 SRW
GETRAG/NV273
P-PUMPED, 2.6" S400
CaptainChrysler
Postby Ace » Wed Oct 29, 2008 1:42 pm
Just because you stack a huge volume of air up behind the manifold doesn't mean it will travel through the combustion chambers any differently than before.
2 cubic feet of air at 10psi looks the same as 200 cubic miles of air at 10psi to the intake valves.
Postby mprmn08 » Wed Oct 29, 2008 2:43 pm
actually if you have more area to stuff the boost it will be more volume. Yes it may still be 10 psi here and 10 psi there but with more cubic area to put it in will be more volume of the same pressure. just think of air compressors. If you have a 5 gallon tank with 50 psi in it theres less air in there then a 50 gallon tank with 50 psi in it.
mprmn08
Postby 1991cummins » Wed Oct 29, 2008 2:47 pm
yah, i agree with ace, unless you see something that would cause restriction... but stock should be ok i would think, i would think a three inch crossover and the stock "mouth of the head" should flow all the air you will need, especially if you have not ported your head yet...
just an opinion though...
1991cummins
