B1 turbo.
B1 turbo.
Postby nojackwayne » Thu Oct 30, 2008 9:42 pm
hey guys, who has used a b1 on their first gen? I can get one, dont have the spec on it yet though.
generally someone comes up with a really thorough explanation around here.(what sizes, boost #'s, personal pref. etc, etc.)
any input is welcome
thanks.
Wayne
92 W250 IC reg auto. H1C w/16cm, boost/pyro/fp, 366spring, DennyT stg II, pump tweaks, k&n, custom bumper, custom dp w/4" exhuast
01 C&C 3500 4x4 man. stock for now
08 C&C 5500 4x4 auto. egr&dpf fell off
nojackwayne
Postby JQmile » Thu Oct 30, 2008 11:38 pm
I've heard laggy but good, I think KTA made 480hp with one.
JQmile
Postby fergavs » Fri Oct 31, 2008 3:52 pm
I have a B1 bomber lying in the shop from a 3rd gen application. I havent tried it yet but might attemp it this weekend. When I called the distributer about it they told me slightly larger comp and bigger turbine housing then stock 3rd gen. So basically it should be about a 60mm comp and 12 or 14mm turbine section. They should support around 400rwhp.
fergavs
Postby KTA » Mon Nov 03, 2008 1:22 pm
There were several versions of the "B-1" Bomber turbos. I made 480+rwhp with one on a 12mm pump, but it was the 62/71mm .80AR version.
Postby Richie O » Mon Nov 03, 2008 3:06 pm
Mine is the 57/64/14 S300G. It works good for me at 300 hp. Borge Warner says mine will support 350 to 400 hp.
Postby nojackwayne » Mon Nov 03, 2008 8:22 pm
I guess the spec on this one is supposed to be 58/64/12. Now I just have to get off my wallet and get it :violin:
nojackwayne
