GOT 2 VE PUMPS LAYIN AROUND
Postby railhor5.9 » Mon Nov 03, 2008 1:47 pm
I HAVE 2 VE PUMPS LAYIN AROUND ONES FINE THE OTHER PUMP DIDNT HAVE ENUF PRESSURE TO POP OFF THE INJECTORS AT START UP... WAT COULD THAT BE? I DNT NO WAT TO DO WITH THEM MAYBE A 14 MM PUMP BUILD???? WAT DO U GUYS THINK...
1993 d250,single cab short bed, sbc, 175hp p-pumped,4kgsk,370's, fass 150. hx35
1997 2500 4x4 , 913,191's,3kgsk,5x16, 3rd gen dubs.
railhor5.9
Postby VEfreak » Mon Nov 03, 2008 5:22 pm
On the one that doesn't pop the injectors, try turning in the fuel screw some, then see if it will work, and please stop writing in caps.
I AM ZUES DAMNIT
VEfreak
Re: GOT 2 VE PUMPS LAYIN AROUND
Postby dpuckett » Mon Nov 03, 2008 5:41 pm
railhor5.9 wrote: WAT DO U GUYS THINK...
I think some grammar and typing skills would be a good start..... :lol:
DP
Postby 92d250 » Mon Nov 03, 2008 5:59 pm
I didn't see we're it asked if he spelled good enough .... If you have the money to do the head and rotor for a 14mm pump do it.
1992 D250 370,000 and counting on the cummins, auto, pump turned up, 6x16, 3200 spring, afc lever mia, boost and pyro guage, single stack, 5 inch lift, shifter with od button on it, potentiomitor..... Next hx40, 285's...
92d250
Postby peobryant » Mon Nov 03, 2008 6:08 pm
DP
:D
Postby railhor5.9 » Mon Nov 03, 2008 7:25 pm
ok you guys, i will try to spell what right, sorry im just always in a hurry to write things i will try harder to spell words properly and to use my grammar properly :roll: . Were can i get 14 mm pump from?
railhor5.9
Postby fasttalker83 » Mon Nov 03, 2008 7:30 pm
rokentech.com has 14mm w/4mm camplate combo for 631.00 that is for the head rotor and camplate only you will have to use one of your old pumps to make it
fasttalker83
Postby cummins king » Mon Nov 03, 2008 9:00 pm
railhor5.9 do you have the truck modifications to support a pump like that?
93 4X4 auto
cummins king
Postby redneckroot » Tue Nov 04, 2008 5:53 am
that website didn't work for me does anyone have the correct one?
redneckroot
Postby redneckroot » Tue Nov 04, 2008 7:35 am
I found it, its http://rocken-tech.com/RotorHeads.html
for some reason my google search didn't work with the first page posted here.
redneckroot
Postby railhor5.9 » Tue Nov 04, 2008 11:24 am
wat all is needed? i have a sbc and a fass fuel pump layin around. Im tryin to find a turbo but no company will leave a generator in one spot for long enough for me to snag a turbo
railhor5.9
