What happened to my smoke?
Postby dpuckett » Sun Nov 09, 2008 7:51 am
I FINALLY got around to changing the lift pump on my pickup to the piston style pump I bought at SOP (it IS hard to change it when the truck is 3 states away). Took it for a test drive, and the smoke went from (my guess based on past trucks) 30-35% to about 5%- just a haze at WOT. Gained a lot of bottom and mid range performance to boot. I would highly recommend the piston pump, even if you arent going all out in the BOMBing.
But that leaves the question of what happened to the smoke? I got to pondering, and came up with this idea: The new pump is getting all pressure and volume my VE can use at this time, allowing the IP to compound the pressure better and better atomze the fuel when it gets to the cylinder. Any better ideas?
Daniel
Postby PToombs » Sun Nov 09, 2008 2:34 pm
I think you got it figgered out pretty good! I bet your fuel mileage goes up too. Not a bad thing at all! ;)
Postby TWorline » Sun Nov 09, 2008 3:39 pm
I was hoping this thread would be about your tailpipe... ;-) Just had to say something since Pete didn't!
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby rbrettctd » Sun Nov 09, 2008 7:30 pm
I noticed the exact same thing with my install today. Kinda curious myself. Def has lots more power than the stocker. Enough to kill my clutch--slips with 3/4 throttle in 3rd 4th and 5th.
Randy
rbrettctd
Postby RumbleFish » Sun Nov 09, 2008 7:30 pm
TWorline wrote:I was hoping this thread would be about your tailpipe... ;-) Just had to say something since Pete didn't!
ya, Pete is an expert with stacks AND a tailpipe. im sure he could have figured out how to hook 'em both up.
Postby PToombs » Mon Nov 10, 2008 6:19 pm
Well, I know how to hook them up, but Bill is the expert on how to make them work. His was pretty nasty at SOP. ;)
:jumpsmile:
Postby Richie O » Mon Nov 10, 2008 6:22 pm
I have found that if I want some alone time all I need to do is add Rasin Bran. Then chase that with beans and I will be working all by myself. 8)
Postby dpuckett » Tue Nov 11, 2008 10:01 am
We had a one-man reenactment of the Blazing Saddles campfire scene at SOP5.
