electric pump vs pistn lp
Postby mtm93ramnasty » Tue Oct 21, 2008 10:52 am
my fuel supply is all stock right now
93 ctd pump maxed, little bit of timing, fuel pin ground, 3200 gov spring, 6x18 injectors, hx40, CoolerTubz, southbend con fe, isspro guages boost+pryo, 5in exhaust, home made intake w/greens airfilter
340hp 739tq no ksb hot wire stock lp
mtm93ramnasty
Postby PToombs » Tue Oct 21, 2008 5:00 pm
BC, you're only running a 3/8's line. That might be the problem right there. Most guys jump to a 1/2 inch.
Have you thought of trying that?
Postby BC847 » Tue Oct 21, 2008 7:17 pm
PToombs wrote:BC, you're only running a 3/8's line. That might be the problem right there. Most guys jump to a 1/2 inch.
To be sure 3/8" will support 400+ HP . . . . ?
Postby DTanklage » Wed Oct 22, 2008 12:40 pm
i am thinkin that if you put a low pressure spring in your l;arge bore lp and lose the bypass your ve will never run it dry
have you tried putting a resriction in the bypass system?
i know you are not supposed to but with the probs you are having i would be thinking outside the box
what inlet fitting is on the lp?
dip stick and -8 line and or bed mounted tank
(vs underbed)
DTanklage
Postby fergavs » Fri Oct 24, 2008 6:56 pm
I ran a piston lift pump for a couple years. that thing worked well for 300-350rwhp. I am gonna install the piston pump on the 91 I just bought. I didn't have a fuel pressure gauge back when I was using the piston lift pump but it never seemed to go dry. When I did my last round of mods I upgraded to the airdog150. I just blasted a hole in the bottom of the tank and use a fitting with a viton seal. I don't use the stock pickup at all. I also have all 1/2" lines and a 3/8's fitting into the IP.
fergavs
Postby Ace » Sat Oct 25, 2008 7:46 am
If there's only one restriction somewhere in the circuit, it doesn't matter how big a line or what pump you use, it will only flow at that lowest common denominator rate, kinda like the weakest link in the chain. An unrestricted low pressure piston pump flows like a fire hose. And BC's right, 3/8 is plenty for some crazy amount of power. I don't know how much, but way more than anyone's talking about here.
I like Don's idea.
Postby DTanklage » Wed Nov 12, 2008 12:42 pm
hey pete, wasnt it you that had a list of the different springs (and pn's) for the sec gen lp?????
anyone know where that list is?
DTanklage
Postby PToombs » Wed Nov 12, 2008 6:26 pm
Not me, but I remember seeing it.
Someplace. :oops:
