injector question
injector question
Postby 1stgenman » Fri Nov 07, 2008 12:14 pm
I'm getting started on my first gen, i have 90 hp bully dog injetors and i have a hx 35 on the way, and i want more power, i just wnat to know how big i could go with my set up, i also have 366 spring on the way, So what would be a good big injector can i go with, the bully dogs where a good injector i just want more, i've got the pump maxed out, any help would be greatly appreciated
92 W250 4x4 with 98 12v engine
84 chevy k30 crew cab 12v ppump engine 370 marines, custom cam plate
1stgenman
Postby rbrettctd » Sun Nov 09, 2008 7:35 pm
Is money an issue? EDM 6x16s seem to be good power makers, though may be little much if you plan on keeping hx35. 6x12s would do good also. If money is an issue, keep what you have for now, get a DennyT stage 2 fuel pin. Good power adder for $100. Piston LP is a good idea to keep the VE wet.
Randy
rbrettctd
Postby dpuckett » Tue Nov 11, 2008 10:10 am
What leads you to believe you have the pump maxxed out? The collar on the fuel screw will come off, but I wouldnt do it before adding a fuel pressure gauge. Heck, I wouldnt run Bully DOg 90s with a stock pump and no FP gauge.
You need to decide what you want in the end and build toward it- buy it once. Or buy it, decide it aint enough and sell it to me for half of retail ;) :D . The BD 90s will spool a HX40 or S300 just fine. 4" exhaust never hurt anyone, either. Get my drift? Get some guages, and establish a baseline, though. Pyro, fuel pressure, boost, tach.
Daniel
Postby JQmile » Tue Nov 11, 2008 11:06 pm
I'm going to be testing some 6x16s soon with an upgraded stock turbo, I'll let ya know how it does.....I think you'll be pretty happy for a while with the pump and injectors.
JQmile
Postby 1stgenman » Thu Nov 13, 2008 7:09 pm
thanks guys, i do have 4 inch exaust i left that out, and i have tried to look into those 6x16s but cant find anywhere
1stgenman
Postby SChandler » Thu Nov 13, 2008 9:13 pm
1stgenman wrote:thanks guys, i do have 4 inch exaust i left that out, and i have tried to look into those 6x16s but cant find anywhere
The 6x16s are a custom deal. You have to call the shops to find out about them. Anyplace that does custom EDM work on injectors can make you a set (in theory). Some shops are better than others, though.
SChandler
Postby 1stgenman » Sat Nov 15, 2008 10:24 am
dpuckett wrote:What leads you to believe you have the pump maxxed out? The collar on the fuel screw will come off, but I wouldnt do it before adding a fuel pressure gauge. Heck, I wouldnt run Bully DOg 90s with a stock pump and no FP gauge.
Daniel
i have taken the collar of i got the screw in as far as it will go
1stgenman
