#$%& TIMING!
#$%& TIMING!
Postby 1991cummins » Sun Nov 16, 2008 12:45 am
ok, i want to bump my timing, i have tried at least ten times with everything i have in my shop full of tools... i cannot get those three stupid nuts loose... so i give up, where can i get the "s" wrench, or how about a picture of it or something...
Thanks,
Derek
1991cummins
Postby burnt_servo » Sun Nov 16, 2008 3:32 am
is there not a bracket on the pump head as well ?
'93 w250 .... stock ...
burnt_servo
Postby Begle1 » Sun Nov 16, 2008 5:55 am
The bracket's easy to get to, the one back behind the pump requires an S-wrench.
I got a set of metric and SAE reversible Gearwrench S-wrenches from Sears for $120...
Then I spent another $100 for a set of metric and SAE Gearwrench halfmoon wrenches...
Postby PToombs » Sun Nov 16, 2008 7:29 am
Try a swivel socket, or DPuckett got his with a crows foot and a few extensions.
I used the blue flame tool and made me a custom bent wrench.
Postby Philip » Sun Nov 16, 2008 7:31 am
Postby Makaio » Sun Nov 16, 2008 7:51 am
Ditto on the link Philip posted. I have a Snap-On pump wrench and it fits like a charm.
Matt
1992 W250 auto, ASA/AFE intake, H1C hybrid 60-16, Bosch 190's, Bully Dog fuel pin, 366 spring, modified pump and a 4" turbo back exhaust. Suncoast valve body plumbing 3.54's w/LSD. Autometer gauges.
Makaio
Postby VEfreak » Sun Nov 16, 2008 11:49 am
my buddy just unbolted his power steering pump and got at the back bolt with a regular ratchet.
I AM ZUES DAMNIT
VEfreak
Postby Begle1 » Sun Nov 16, 2008 3:54 pm
VEfreak wrote:my buddy just unbolted his power steering pump and got at the back bolt with a regular ratchet.
But that's just way, way, way too much work. :roll:
Instead of doing that I wasted an hour or so the first time trying to put a stubby wrench on it and hit the stubby wrench from down under with a hammer and two foot punch.
I actually got it off the first time with a universal joint and a socket, but I couldn't put it back on that way without torquing off the socket.
But without a S-wrench, it's a power steering/ vacuum pump removal job.
Postby randyswelding » Sun Nov 16, 2008 6:01 pm
heres what i did got a cheapy 13mm wrench and heated it up and made an s wrench.wala a maybe 15 dallor tool(torch gas and tool its self) and be done with it :D thats my opinion good luck either way ya go
randyswelding
Postby gear jammer 91" » Sun Nov 16, 2008 9:43 pm
Check your local tool stores, I found a half moon wrench set for $20 at the local MCK Tool.
01 LB7
gear jammer 91"
Postby 1991cummins » Sun Nov 16, 2008 9:44 pm
thanks for all the help guys, i will try the torch method considering between me and my dad have at least 5 complete sets of standard wrenches :lol: and if that dont work i will just buy the one philip showed me.
thanks,
Derek
1991cummins
