bosch p-pump
bosch p-pump
Postby T.winegar » Tue Nov 18, 2008 8:01 pm
is it possible to turn up the bosch p-pump like the ve pump?? if it is, how do i do it??
89 727-stageIvcomp 4in intake-amsoil air filter, 4in exhaust, dennyT, 366 spring. pump turned up to make me smile! low stall converter, rebuilt tranny at 120,000miles
T.winegar
Postby gear jammer 91" » Tue Nov 18, 2008 8:36 pm
To turn up a p pump you need to replace the fuel plate with a new one. I think you can slide them forward for a little more power, or maybe grind your own plate, there is no screw to turn up though.
01 LB7
gear jammer 91"
Postby roxxx » Fri Nov 21, 2008 6:20 pm
there are all sorts of mods for the p-pump Govern ,delivery valves,cam plate ,plus more stuff it just depends on how much money you want to spend on it
Edit .... most of this stuff is not as easy as the Ve pump to do though
1992 4x4 Reg cab LE 5 speed
4 Inch lift
Bilsteins shocks 5125
VE moderately molested
Dana 80
ultra wheel rims Type 164
ASA pipe BHAF 19037
Outerwears prefilter
A A nv4500
roxxx
