Injectors in
Injectors in
Postby 92d250 » Thu Oct 30, 2008 2:00 pm
Well heres a vid of the injectors
1992 D250 370,000 and counting on the cummins, auto, pump turned up, 6x16, 3200 spring, afc lever mia, boost and pyro guage, single stack, 5 inch lift, shifter with od button on it, potentiomitor..... Next hx40, 285's...
92d250
Postby peobryant » Fri Oct 31, 2008 10:34 pm
Need new tires yet? :lol:
Postby 2stroke » Thu Nov 06, 2008 8:32 pm
is that just the 6x 16`s and the stock turbo? would that work? wouldnt that be too mucch fuel?
91 non I/C w-350 SRW
2stroke
Postby cummins king » Thu Nov 06, 2008 9:34 pm
if its a stock turbo i bet you could see 1800 F+ for you etg's
93 4X4 auto
cummins king
Postby 92d250 » Tue Nov 18, 2008 9:05 pm
if everything was stock and had 6x16 injectors would it cause it to run bad? when i floor it it makes lots of noise and feels like its missing? smokes white?
92d250
Postby CumminsPride » Wed Nov 19, 2008 9:40 am
Retarded timing. You may need to throw your AFC back in and push the pump to the head. You may be running the IP out of fuel too.
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby 92d250 » Wed Nov 19, 2008 12:59 pm
It does the same thing as the guys dyno video with 6x18s it was a recent one would you happen to no what that is... I am planing on getting a walbro 392 I think it is a 255lpm would that be able to keep up with those injectoes?
92d250
