3200 spring
3200 spring
Postby 2stroke » Sun Feb 18, 2007 10:14 am
how will it act on my auto? noone ever talks about autos, just getrags.
2stroke
Postby wannadiesel » Sun Feb 18, 2007 10:23 am
It's very nice on the automatics as well. From a performance standpoint, the engine is still making power when the trans shifts, instead of the stock setup where the power has fallen off by the time the trans gets around to shifting. It's nice for towing, too, because you can hold drop out of OD when trans temps get too high and still maintain road speed.
Best dyno: 408/844
wannadiesel
diesel guru
Postby 2stroke » Sun Feb 18, 2007 11:01 am
so i will be happy with it on my 727?
2stroke
Postby gman07 » Sun Feb 18, 2007 12:16 pm
The spring is also nice on the autos for the simple fact that it takes less pedal to drive. I also can run 70+MPH in 3rd now, which as Dave said, is good for towing.
gman07
Postby wannadiesel » Sun Feb 18, 2007 6:05 pm
2stroke wrote:so i will be happy with it on my 727?
Want another 15 mph of top end?
Best dyno: 408/844
wannadiesel
diesel guru
Postby 2stroke » Sun Feb 18, 2007 6:30 pm
nice
91 non I/C w-350 SRW
2stroke
Postby holeshotracing » Sun Feb 18, 2007 7:12 pm
Not to hijack your thread, but where do you buy a 3200 spring? I've poked around on some diesel places and can't seem to find one. Do they suck to put in?
Black 1993 regular cab W250, G-trag, NP205, 262K, muffler gone, Isspro tach & boost
holeshotracing
Postby 92 D/UNIT » Sun Feb 18, 2007 7:25 pm
peirs diesel research http://www.piersdiesel.com/DodgeUSPrice.htm not the funnest thing to put in but well worth it.
388/886
92 D/UNIT
Postby wannadiesel » Mon Feb 19, 2007 3:27 pm
The best place to get one is at a diesel injection shop. There's at least one in every decent sized city.
Best dyno: 408/844
wannadiesel
diesel guru
Postby PToombs » Mon Feb 19, 2007 4:53 pm
I paid $15 for mine at my local pump shop. When you pull the old one off, the piece it's attached to will go flying if you are not careful. :oops: Un hook it from the throttle arm, then let it off slowly.
